Announcements
How to make part of the object morph following a path
I am trying to make my character have this sort of effect: only one part of the body is morphing along the path, not the whole body, the examples below are videos from Balenciaga's instagram. I was trying using Curve Warp but I can only get the whole body moving along the path instead of just one part. Any ideas how to do that??
Screen Shot 2018-11-21 at 12.15.58 AM.pngScreen Shot 2018-11-21 at 12.16.08 AM.pngScreen Shot 2018-11-21 at 12.16.19 AM.pngScreen Shot 2018-11-21 at 12.16.29 AM.png
dinofiguera
For the first three images, you only need a simple bend deformer.
For the fourth one, you can use the curve Wrap, but you have to build a straight curve going from the head to the feet first, Then apply the deformer, and after that, shape your curve.
I found actually easier to use a simple wire deformer (one of the most powerful Maya deformers)
in combination with a twist deformer. (applying the twist before the wire).
So the trick is to create a straight curve first and to deform your character with it...
Check my attached scene,
Cheers
OMG, you are a genius!! Thank you so much!!!
