Announcements
Weird visualisation of curves in graph editor.
EpicMeh
Message 1 of 8
EpicMeh
Hi, my curves for keyframes of all attributes in maya started acting strangely graphically, there is no problems really with the animation but I can't really tweak it if I can't see the change properly.
Here is some screenshots:
1: here is the problem
2: just moved the work area
3: works fine in linear mode and stepped.
Replies (7)
Message 2 of 8
Strange your query is unanswered. well i am also on the same page goggled about this strange thing in Graph editor.
at first i thought its maya's graph is diffident t from other software. too bad we consumers have to deal with the job of who had one job called bug fixing developers. and half of the time users goggling about bugs and creepy Glitches, reopening maya after several crashes.
Btw. after sometime on Pc i unpurposely delete all the junk on pc. yeah TEMP. Deleting temporary files.
For windows just search for %temp% and delete all the files permanently. then reopen Maya.
Thank me later.
Message 3 of 8
Hi
Did you find the solution of your problem? I have the same problem and temp deleting didn't work.
Message 4 of 8
EpicMeh
I didn't really solve the issue, however, deleting your prefsfolder in the document/maya/20xx removed the problem.
Message 5 of 8
Thank you
Unfortunately , it did't help me
Message 6 of 8
Cavaliere.fab
Hi...did you solve this problem?
A friend of mine has the same one where only the modern graph editor is affected.
Does anyone have a solution?
Message 7 of 8
I changed graph editor ui from modern to classic in preferences. It helped but not really comfortable in using.
Message 8 of 8
grendizerus
I have a problem that looks like your. Sometimes the Graph editor will act strangely.
For example I have 5 keyframes, at frames 1, 10, 20, 30 and 40.
The animation curve will pass through keyframes 1, 10, 30, then it will jump back to keyframe 20 and then will jump forward to keyframe 40. I never saw this before in any other app... I'm using Maya 2020.3.
Next time it happens, I'll take a screenshot.
