Flow path object U-turn front to back
Message 1 of 1
I am working on my bachelor project and this problem came up.
I am attaching an object to a motion path (no history, freezed transformation) and then I want to make this object flow on this path. The problem is that the lattice rotates this object front to back.
Inverse front in Obejct Attribute Editor under motion path doesn't work püroperly - it mirrors an object. Lattice rotation also doesn't work.
If anyone had the same problem then please let me know. Thank you
First picture shows the right direction of an object.
The second one a wrong rotated object after using the command flow.
The third after inversing it front.
Replies (0)
