Channel Box dragging in 1 unit increments
When I drag any the channel box value, it changes in 1 unit increments. I want to drag in smaller increments, super smoothly... Like when you select the Channel Box attribute, then drag in the Viewport.
Is this just the way Channel Box value drag behaves, or am I stuck in some setting I don't know about?
Hey @Anonymous
Something tells me you have increments turned on accidentally on your move, rotate and scale settings... go to the far left.. you will see a square with 4 triangles on each side, thats the move button.. double click it.. now click the "reset tool" on the top... now try doing what you were doing with the channel box.. if it doesn't do increments anymore, do the same thing for rotate and scale now! (:
____________________
Daniel López de Medrano
Remote Character Rigger
*14+ hour Rigging Course*
That was it, thanks Daniel!
I have this exact problem but unfortunately the suggested answer here doesn't work for me.
I've try everything but I can't get the channel box to behave normally, it only increments values by 1 unit at the time.
Anyone have an idea?
