Cannot Paint different BlendShape Weights on Different Targets
So I have a bunch of blend shapes on one node. I select the Base Mesh go to the Paint Blend Shape Weights Tool. Under Targets I see my main node and I see all my subsequent blendshapes. I select a blendshape target and paint no problem. Then I select another target and it does not change. I'd like to paint different weights on the different targets. How can I do this?
Thank You,
William
OK this is Why I want to do this. When I change the blendshape value from 0-1 I get extra movement. I thought I sculpted other vertices on accident but when i compared the meshes to the original they are exactly how I want them. Im getting extra vertex movement somehow or from somewhere. However, ALL of the blendshapes have extra movement in the exact same way so there is some thing common here.
