anyone know why I can´t get icon on all my marco buttons?
If i use the liltte icon it work if i use the large icon.. it does not
Solved by _dscholtes_. Go to Solution.
Solved by JhoelForshav. Go to Solution.
Make sure the dimensions of the image is 32x32 and the bit depth is not more than 24.
You can check this by right clicking the bmp-file, select properties and go to details tab.
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
I'm going to assume you have the naming and icon sizing right.
I sometimes have the same issue when I save an icon as 32-bit file or let paint.net auto-detect the bit depth. Saving it as 24-bit file resolves the issue for me.
[edit] I see the correct answer has been given in the mean time [/edit]
Comment removed since you have already checked my remarks.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
