There is a screenshot here...
looking-for-sample-c-addin-with-button-added-to-a-ribbon-panel
...which shows a Inventor project type template. But where can I get that to install onto VS 2019 for Inventor (2019)
TIA!
Solved by bradeneuropeArthur. Go to Solution.
Install the SDK tools found in one of the folders of Autodesk
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Thanks for that. It works in VS 2017, but not in VS2019... any suggestions?
TIA,
Owen
