Virtual studio can't declare Inventor application.
FINET_Laurent
Advisor Advisor
Message 1 of 15
FINET_Laurent
I'm trying to make an EXE for inventor using Virtual studio.I've created a new project and tried to declare the Inventor application but I can't do it. I've looked through the internet, sample files etc..
Is there a secret trick to it ?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Replies (14)
Message 2 of 15
FINET_Laurent
I'm refering to those lines  :
Dim oInventorApp As Inventor.Application
oInventorApp = GetObject( , "Inventor.Application")
The " Get Object " is not defined.. =C
Message 3 of 15
sundars
Hi @FINET_Laurent
Did you mean Visual Studio? If it's visual studio you can create an Addin DLL which can be loaded into Inventor. Are you specifically looking to create a stand alone exe?
You can access the SDK samples here: C:\Users\Public\Documents\Autodesk\Inventor 2021\SDK
- Run "developertools.msi"
- This will extract the SDK folders
- Navigate to C:\Users\Public\Documents\Autodesk\Inventor 2021\SDK\DeveloperTools\Samples
- you will see sample projects which you can customize.
Hope that helps.
-shiva
Shiva Sundaram
Inventor Development
Message 4 of 15
sundars
Hi @FINET_Laurent
objInventorApp = GetObject( , "Inventor.Application") is a microsoft call - https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/getobject-functio....
It should work, if you have built the project correctly. Can you take a look at the standalone VBA sample programs in the SDK folder. They use the same logic and execute GetObject().
-shiva
Shiva Sundaram
Message 5 of 15
FINET_Laurent
I've changed to framework 5.0 and got the execute the command :
Imports Inventor
Public Class Form1
Private Sub Ola_Click(sender As Object, e As EventArgs) Handles Ola.Click
Dim oApp As Inventor.Application
oApp = GetObject(, "Inventor.Application")
Dim oDoc As AssemblyDocument = oApp.ActiveDocument
End Sub
End Class
But the oApp is empty.. :C
Message 6 of 15
sundars
Interesting. Did it use to work with .NET 4.7/4.8? I dont see why that would fail with .Net 5.0.
Can you check to see if you can call GetObject() on any other application?
-shiva
Shiva Sundaram
Message 7 of 15
sundars
You could also try
Dim oApp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
Reference:
https://adndevblog.typepad.com/manufacturing/2012/07/run-vba-macro-using-inventor-api.html
-shiva
Shiva Sundaram
Message 8 of 15
FINET_Laurent
Thank you for taking your time to answer.
Unfortunately I'm out of the officie until monday..
I'll try those and let you know asap.
Also this is the very first time I'm using Visual Studio.. ^^'
Thanks again,
FINET L.
Message 9 of 15
johnsonshiue
Hi Laurent,
Another thing to watch out is that Inventor Apprentice Server is a separate install on top of Inventor now. If you need it, go to the following page.
https://knowledge.autodesk.com/support/inventor/downloads/caas/downloads/content/inventor-apprentice...
Many thanks!
Software Test Engineer
Message 10 of 15
FINET_Laurent
Hi, I installed every thing but it's still not working... I have Inventor 2021 & Visual studio 2019..
Message 11 of 15
FINET_Laurent
Tried too.. It's like the application doesn't exist...
Message 12 of 15
sundars
Hi @FINET_Laurent
After installing visual studio did you restart your computer (silly question - but just making sure). Another thing you can try is calling GetObject() on a different application - not Inventor, but notepad or paint or Excel and see if that works. If not, then there may be something else going on your machine. If it's only a problem with Inventor, then either there is something incorrect with your installation or your vba project.
If nothing else works, you can zip up your project with just the code which doesnt work and send it to usWe can try to take a look at it.
-shiva
Shiva Sundaram
Message 13 of 15
FINET_Laurent
I indeed can't get any application object..
Anyway I tried using the addin template and got something to work (close the application when pressing a button), so I guess I'll go this way instead.
I'll dig further down to see if I'm configuring the project wrong or something...
FINET L.
Message 14 of 15
bradeneuropeArthur
@johan.degreef  had similar things with Excel.
He can maybe help you out!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 15 of 15
pockybum522
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/getting-inventor-object-in-net-core/td-...
Please check out this post for how to Marshal a COM object in .NET 5.
