Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VBA metod "Component Offset"
8 REPLIES 8
Message 1 of 9
anton_voitin
305 Views, 8 Replies
Hi all. I'm interested in how to get to the method of these commands in VBA. Thanks for any help
8 REPLIES 8
Message 2 of 9
where is this original command found:
Part
Assembly
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 3 of 9
This is clear to me. I want to use this command in my macro. how can I apply it in VBA code? Is it possible to show an example?
Message 4 of 9
Yes I know.
But I need to know where the original command is located, then I can help your further!
Arthur Knoors
Message 5 of 9
FYI:  I believe that is one of the selection methods.
The online help for this can be found under the "Select Command Reference" topic.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-3E3537A9-565E-4F2E-B69D-069EDCDF1AE1
There is usually a selection filter type drop-down in the Quick Access toolbar with something in its list labeled "Select Component Offset...".  I'm not familiar with it either.
Wesley Crihfield
(Not an Autodesk Employee)
Message 6 of 9
anton_voitin
in reply to: WCrihfield
Yes, this is the same method. Everything I found in the selection priorities. But I don’t see anything suitable or am I missing something?
Message 7 of 9
It is an internal Command: AssemblyEnhSelComponentBBCmd
The Spherical Select is: AssemblyEnhSelSphereCmd
Both require user action.
Don't know if it's possible to program any input.
Call ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyEnhSelComponentBBCmd").Execute
Message 8 of 9
Thank you very much. I tried searching among the commands but couldn't find it. And now you rubbed my nose in) Now I’ll try to work with this, thank you very much.
Message 9 of 9
Use EventWatcher from the SDK.
