Is there a VBA way to fill a custom Inventor 2018 Material Library file (.adsklib) with data from an Excel sheet?
Thanks in advance!
Greetings, Joris
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Thanks for your reply.
I made a small setup in excel. I would like to export the excel data into my custom inventor library.
So excel is the master document with all the material specific data included. Is there a way with some nice VBA?
Greetings, Joris
Arthur Knoors
