vb.net push space key in Textbox of Userform opens new file dialog in nventor
Ralph
Message 1 of 18
Ralph
Hello at all,
i've created a userform which allows users to fill in some values which will be stored in titleblock. The usreform will popup when a new drw file
will be opened. Within these uf there are several textboxes. If I would like to write a space in these textboxes Inventor opens "New File Dialog".
Is there anyone who have same problems or a solution for this.
Thanks in advance
Ralph
VS 2015
Inventor Prof 2016 - 64 bit Edition - Build: 138, Release: 2016 RTM Update 2
Replies (17)
Message 2 of 18
bradeneuropeArthur
For my understanding:
if you fill in a space like " " then you want to see the file open dialog.
Comment:
Please don't use Abbreviations if not marked as Userform (UF) for readability.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 18
bradeneuropeArthur
 Private Sub TextBox1_TextChanged(sender As Object, e As EventArgs) Handles TextBox1.TextChanged
        If TextBox1.Text = " " Then
            Dim N_FileDialog As New OpenFileDialog
            If (N_FileDialog.ShowDialog() = DialogResult.OK) Then
"YOUR CODE HERE
End If End If End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 18
Ralph
thanks for response.
No I don't want to open it, but it opens after pressing space key.
Message 5 of 18
bradeneuropeArthur
see the code:
it will open the "FileDialog" (FD) when the "Space" is pressed.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 18
Ralph
HI,
I understand the code but this isn't how it should work.
I will explain it in step's:
1. open Inventor
2. open a new drawing (new file dialog)
3. my own Userform opens automatically (controlled by Invetor events)
4. filling textboxes in my own userform for example ("DIN 76")
When I press the "space" key after I'vw wrote "DIN" in the textbox the "new file dialog" opens automatically but it shouldn't.
Hopefull my problem is now more clear.
Message 7 of 18
bradeneuropeArthur
Could you upload the code?
Maybe I have an idea!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 18
Ralph
the complete project or only code of Userform?
Message 9 of 18
bradeneuropeArthur
but I would like to see how you defined the Userform, and how you show this.
Also I want to see how you defined the filedialog and how you show this
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 18
Ralph
ok so first you will find code of Userform and at second i've added code of "StandardAddInServer" which ncludes inventor events and therefrom the userform will be started
Code of Userform:
Imports System
Imports System.Type
Imports System.Activator
Imports System.Deployment
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Imports Inventor
Imports System.Resources
Imports System.Globalization
Imports System.ComponentModel
Imports myInvDrwEvents
<Assembly: NeutralResourcesLanguage("en-US")>
Namespace myInvDrwEvents
    Partial Public Class FrmStart
        'Version 1.0.1 - Updated to VisualStudio 2015 --> Version Angabe unter Projekteigenschaften->Ressource
        Inherits Form
        Public Shared sCS() As String = {"@@"} 'Separator
        Public Const sRS As String = "@@"    'ReplaceString --> vbcrlf
        Dim oApp As Inventor.Application
        Dim blnStarted As Boolean = False
        Sub New()
            'MessageBox.Show("vor 'InitializeComponent()' Aufruf", "Sub New", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Information)
            ' This call is required by the designer.
            ' Add any initialization after the InitializeComponent() call.
            Try
                oApp = Marshal.GetActiveObject("Inventor.Application")
            Catch ex As Exception
                Try
                    Dim invAppType As Type = GetTypeFromProgID("Inventor.Application")
                    oApp = CreateInstance(invAppType)
                    oApp.Visible = True
                    'Note: if you shut down the Inventor session that was started
                    'this(way) there is still an Inventor.exe running. We will use
                    'this Boolean to test whether or not the Inventor App  will
                    'need to be shut down.
                    blnStarted = True
                Catch ex2 As Exception
                    MsgBox(ex2.ToString())
                    MsgBox("Unable to get or start Inventor", "frmStart - New()")
                End Try
            End Try
        End Sub
        Private Sub frmStart_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
            cFunctions.LogEvent("Bin in frmStart - frmStart_Load()",,,,, False)
            'MessageBox.Show(GetVersionInfo(True), "Form1_Load", MessageBoxButtons.OK, MessageBoxIcon.Information)
            If oApp.Documents.Count = 0 Then
                MsgBox("Need to open an Drawing document")
                Return
            End If
            If oApp.ActiveDocument.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
                MsgBox("Need to have an Drawing document active")
                Return
            End If
            Dim oDrawDoc As DrawingDocument
            oDrawDoc = oApp.ActiveDocument
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - frmStart_Load() - nach 'Dim oDrawDoc As DrawingDocument' - oDrawDoc.DisplayName= " & oDrawDoc.DisplayName)
            ' Obtain a reference to the desired border defintion.
            Dim oTitleBlockDef As TitleBlockDefinition
            For Each oTitleBlockDef In oDrawDoc.TitleBlockDefinitions
                cFunctions.LogEvent("Bin in frmStart - frmStart_Load() - oTitleBlockDef.Name:", oTitleBlockDef.Name)
                Me.cboAuswahl.Items.Add(oTitleBlockDef.Name)
            Next
            'Dim oCI As CultureInfo = CultureInfo.CreateSpecificCulture("en-US")
            Dim oCI As CultureInfo = CultureInfo.CurrentCulture
            Dim oRM As New ResourceManager("myInvDrwEvents.Desc_" & oCI.Name, System.Reflection.Assembly.GetExecutingAssembly)
            With Me
                .Text = String.Concat(oRM.GetString("frmStart"), Space(1), GetVersionInfo(True))  'My.Resources.Version)
                .lblTmpFileName.Text = String.Concat(oRM.GetString("lblTempFileName"), Space(1), .lblTmpFileName.Text)
                .Label0.Text = oRM.GetString("Label0")
                .Label1.Text = oRM.GetString("Label1")
                .Label2.Text = oRM.GetString("Label2")
                .Label3.Text = oRM.GetString("Label3")
                .Label4.Text = oRM.GetString("Label4")
                .Label5.Text = oRM.GetString("Label5")
                .Label6.Text = oRM.GetString("Label6")
                .Label7.Text = oRM.GetString("Label7")
                .Label8.Text = oRM.GetString("Label8")
                .Label9.Text = oRM.GetString("Label9")
                .Label10.Text = oRM.GetString("Label10")
                .lblHoch.Text = oRM.GetString("lblHoch")
                .lblQuer.Text = oRM.GetString("lblQuer")
                .lblAuswahlTxt.Text = oRM.GetString("lblAuswahlTxt")
                .btnCancel.Text = oRM.GetString("btnCancel")
                .btnOK.Text = oRM.GetString("btnOk")
                .gbEingabe.Text = oRM.GetString("gbEingabe")
                .gbAuswahl.Text = oRM.GetString("gbAuswahl")
                .gbBlattformat.Text = oRM.GetString("gbBlattformat")
                .gbOrientierung.Text = oRM.GetString("gbOrientierung")
                .rbDinA0.Text = oRM.GetString("rbDinA0")
                .rbDinA1.Text = oRM.GetString("rbDinA1")
                .rbDinA2.Text = oRM.GetString("cbDinA2")
                .rbDinA3.Text = oRM.GetString("rbDinA3")
                .rbDinA4.Text = oRM.GetString("rbDinA4")
                .rbQuer.Text = oRM.GetString("rbQuer")
                .rbHoch.Text = oRM.GetString("rbHoch")
                .TextBox0.Text = Date.Now.ToString("d", CultureInfo.CurrentCulture)  'oRM.GetString("Textbox0") 'Bearb.-Datum
                .TextBox1.Text = oRM.GetString("Textbox1") 'Maßstab
                .TextBox2.Text = oRM.GetString("Textbox2") 'Ursprung
                .TextBox3.Text = oRM.GetString("Textbox3") 'Fremdzeichnungsnr.
                .TextBox4.Text = oRM.GetString("Textbox4") 'Werkstoff
                .TextBox5.Text = oRM.GetString("Textbox5") 'Maßstab2
                .TextBox6.Text = oRM.GetString("Textbox6") 'Gewicht - in Acad nicht verwendet
                .TextBox7.Text = Year(Now()) 'oRM.GetString("Textbox7") 'Jahr
                .TextBox8.Text = oRM.GetString("Textbox8").Replace(sRS, vbCrLf) 'Toleranz
                Dim sRetStr As String = oRM.GetString("cboBearbeiter")
                sRetStr = sRetStr.Replace(sRS & " ", sRS)
                sRetStr = sRetStr.Replace(" " & sRS, sRS)
                .cboBearbeiter.DataSource = sRetStr.Split(sCS, StringSplitOptions.RemoveEmptyEntries)
                .AcceptButton = Me.btnOK
                .CancelButton = Me.btnCancel
                .gbEingabe.Visible = False
                .btnCancel.Enabled = True
                .btnOK.Enabled = False
                .rbDinA0.Checked = True
                'Einstellungen laden
                Me.cboBearbeiter.Text = My.Settings.Bearbeiter
            End With
        End Sub
        Private Sub frmStart_FormClosed(ByVal sender As Object, ByVal e As FormClosedEventArgs) Handles Me.FormClosed
            If blnStarted Then
                oApp.Quit()
            End If
            oApp = Nothing
        End Sub
        Private Sub btnCancel_Click(sender As System.Object, e As System.EventArgs) Handles btnCancel.Click
            If blnStarted Then
                oApp.Quit()
            End If
            Me.Close()
            oApp = Nothing
        End Sub
        Private Sub btnOk_Click(sender As System.Object, e As System.EventArgs) Handles btnOK.Click
            cFunctions.LogEvent("Bin in frmStart - btnOK_Click()")
                Return
            End If
                Return
            End If
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - nach 'Dim oDrawDoc As DrawingDocument' - oDrawDoc.DisplayName= " & oDrawDoc.DisplayName)
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - vor 'Dim oTitleBlockDef As TitleBlockDefinition'")
            oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item(Me.cboAuswahl.SelectedItem.ToString)
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - vor 'Dim oSheet As Sheet'")
            Dim oSheet As Sheet
            oSheet = oDrawDoc.ActiveSheet
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - vor 'If Not oSheet.TitleBlock Is Nothing Then'")
            ' Check to see if the sheet already has a title block and delete it if it does.
                oSheet.TitleBlock.Delete()
            End If
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - vor 'Select Case CLng(Me.Tag)' - " & CLng(Me.Tag))
            'Check and Set SheetSize and Orientation if neccessary
            oSheet.Orientation = PageOrientationTypeEnum.kLandscapePageOrientation
                Case 0
                    oSheet.Size = DrawingSheetSizeEnum.kA0DrawingSheetSize
                Case 1
                    oSheet.Size = DrawingSheetSizeEnum.kA1DrawingSheetSize
                Case 2
                    oSheet.Size = DrawingSheetSizeEnum.kA2DrawingSheetSize
                Case 3
                    oSheet.Size = DrawingSheetSizeEnum.kA3DrawingSheetSize
                Case 4
                    oSheet.Size = DrawingSheetSizeEnum.kA4DrawingSheetSize
                    If Me.rbHoch.Checked = True Then oSheet.Orientation = PageOrientationTypeEnum.kPortraitPageOrientation
            End Select
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - nach 'Select Case CLng(Me.Tag)'")
            ' This title block definition contains one prompted string input. An array
            ' must be input that contains the strings for the prompted strings.
            Dim sPromptStrings(0 To 8) As String
            Dim i As Integer
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - vor 'For i = LBound(sPromptStrings) To UBound(sPromptStrings)' - i=" & LBound(sPromptStrings) & " To " & UBound(sPromptStrings))
                sPromptStrings(i) = " "
            Next
            ' Add an instance of the title block definition to the sheet.
            Dim oTitleBlock As TitleBlock
            Dim oTextBox As Inventor.TextBox
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - vor 'For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes'")
            oTitleBlock = oSheet.AddTitleBlock(oTitleBlockDef, , sPromptStrings)
            Dim strGewicht = ""
            If Not Me.TextBox6.Text.EndsWith("kg") Then strGewicht = String.Concat(Me.TextBox6.Text.Trim, " kg")
                'Debug.Print oTextBox.FormattedText
                If InStr(1, oTextBox.FormattedText, "&lt;ErstellDatum&gt") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, Me.TextBox0.Text)
                If InStr(1, oTextBox.FormattedText, "&lt;Maßstab&gt") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, Me.TextBox1.Text)
                If InStr(1, oTextBox.FormattedText, "&lt;Ursprung&gt") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, Me.TextBox2.Text)
                If InStr(1, oTextBox.FormattedText, "&lt;Fremdzeichnungsnr.:&gt") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, Me.TextBox3.Text)
                If InStr(1, oTextBox.FormattedText, "&lt;Werkstoff&gt") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, Me.TextBox4.Text)
                If InStr(1, oTextBox.FormattedText, "&lt;weitere Maßstäbe&gt") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, Me.TextBox5.Text)
                If InStr(1, oTextBox.FormattedText, "&lt;Gewicht&gt") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, strGewicht)
                If InStr(1, oTextBox.FormattedText, "Jahr") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, Me.TextBox7.Text)
                If InStr(1, oTextBox.FormattedText, "&lt;Allg. Toleranz Iso 2768-&gt") <> 0 Then Call oTitleBlock.SetPromptResultText(oTextBox, Me.TextBox8.Text)
            Next
            'Einstellungen speichern
            My.Settings.Bearbeiter = Me.cboBearbeiter.Text
            cFunctions.LogEvent(Space(5) & "Bin in frmStart - btnOK_Click() - nach Schleife oTitleBlock.Definition.Sketch.TextBoxes")
            oApp.CommandManager.StartCommand(CommandIDEnum.kZoomAllCommand)
            Me.Close()
        End Sub
        Private Sub cboAuswahl_SelectedIndexChanged(sender As System.Object, e As System.EventArgs) Handles cboAuswahl.SelectedIndexChanged
            With Me
                .gbEingabe.Visible = True
                .TextBox1.Select()
                .btnOK.Enabled = True
            End With
        End Sub
        Private Sub rbDinA0_CheckedChanged(sender As System.Object, e As System.EventArgs) Handles rbDinA0.CheckedChanged
            With Me
                .rbQuer.Checked = True
                .rbHoch.Enabled = False
                .Tag = 0
            End With
        End Sub
        Private Sub rbDinA1_CheckedChanged(sender As System.Object, e As System.EventArgs) Handles rbDinA1.CheckedChanged
            With Me
                .Tag = 1
            End With
        End Sub
        Private Sub rbDinA2_CheckedChanged(sender As System.Object, e As System.EventArgs) Handles rbDinA2.CheckedChanged
            With Me
                .Tag = 2
            End With
        End Sub
        Private Sub rbDinA3_CheckedChanged(sender As System.Object, e As System.EventArgs) Handles rbDinA3.CheckedChanged
            With Me
                .Tag = 3
            End With
        End Sub
        Private Sub rbDinA4_CheckedChanged(sender As System.Object, e As System.EventArgs) Handles rbDinA4.CheckedChanged
            With Me
                .rbHoch.Enabled = True
                .Tag = 4
            End With
        End Sub
        Private Sub btnInfo_Click(sender As Object, e As EventArgs) Handles btnInfo.Click
            MessageBox.Show(Me, GetVersionInfo(False), "myAcadEvents", MessageBoxButtons.OK, MessageBoxIcon.Information)
        End Sub
        Private Sub TextBox6_TextChanged(sender As System.Object, e As System.EventArgs)
            'TextBox Gewicht
            If Not IsNumeric(TextBox6.Text) Then TextBox6.Clear()
        End Sub
#Region "frmStart_Designer"
        Friend WithEvents TextBox6 As Windows.Forms.TextBox
        Friend WithEvents lblQuer As Label
        Friend WithEvents lblHoch As Label
        Friend WithEvents rbQuer As RadioButton
        Friend WithEvents cboBearbeiter As ComboBox
        Friend WithEvents Label0 As Label
        Friend WithEvents Label10 As Label
        Friend WithEvents TextBox0 As Windows.Forms.TextBox
        Friend WithEvents TextBox8 As Windows.Forms.TextBox
        Friend WithEvents TextBox5 As Windows.Forms.TextBox
        Friend WithEvents rbHoch As RadioButton
        Friend WithEvents TextBox7 As Windows.Forms.TextBox
        Friend WithEvents gbOrientierung As GroupBox
        Friend WithEvents lblTmpFileName As Label
        Friend WithEvents btnCancel As Button
        Friend WithEvents btnOK As Button
        Friend WithEvents TextBox4 As Windows.Forms.TextBox
        Friend WithEvents btnInfo As Button
        Friend WithEvents TextBox3 As Windows.Forms.TextBox
        Friend WithEvents gbBlattformat As GroupBox
        Friend WithEvents TextBox2 As Windows.Forms.TextBox
        Friend WithEvents TextBox1 As Windows.Forms.TextBox
        Friend WithEvents Label9 As Label
        Friend WithEvents Label8 As Label
        Friend WithEvents Label7 As Label
        Friend WithEvents Label6 As Label
        Friend WithEvents Label5 As Label
        Friend WithEvents Label4 As Label
        Friend WithEvents Label3 As Label
        Friend WithEvents gbAuswahl As GroupBox
        Friend WithEvents cboAuswahl As ComboBox
        Friend WithEvents lblAuswahlTxt As Label
        Friend WithEvents Label2 As Label
        Friend WithEvents Label1 As Label
        Friend WithEvents gbEingabe As GroupBox
        Friend WithEvents rbDinA4 As RadioButton
        Friend WithEvents rbDinA3 As RadioButton
        Friend WithEvents rbDinA2 As RadioButton
        Friend WithEvents rbDinA1 As RadioButton
        Friend WithEvents rbDinA0 As RadioButton
        Private Sub InitializeComponent()
            Dim resources As System.ComponentModel.ComponentResourceManager = New System.ComponentModel.ComponentResourceManager(GetType(FrmStart))
            Me.TextBox6 = New System.Windows.Forms.TextBox()
            Me.lblQuer = New System.Windows.Forms.Label()
            Me.lblHoch = New System.Windows.Forms.Label()
            Me.rbQuer = New System.Windows.Forms.RadioButton()
            Me.cboBearbeiter = New System.Windows.Forms.ComboBox()
            Me.Label0 = New System.Windows.Forms.Label()
            Me.Label10 = New System.Windows.Forms.Label()
            Me.TextBox0 = New System.Windows.Forms.TextBox()
            Me.TextBox8 = New System.Windows.Forms.TextBox()
            Me.TextBox5 = New System.Windows.Forms.TextBox()
            Me.rbHoch = New System.Windows.Forms.RadioButton()
            Me.TextBox7 = New System.Windows.Forms.TextBox()
            Me.gbOrientierung = New System.Windows.Forms.GroupBox()
            Me.lblTmpFileName = New System.Windows.Forms.Label()
            Me.btnCancel = New System.Windows.Forms.Button()
            Me.btnOK = New System.Windows.Forms.Button()
            Me.TextBox4 = New System.Windows.Forms.TextBox()
            Me.btnInfo = New System.Windows.Forms.Button()
            Me.TextBox3 = New System.Windows.Forms.TextBox()
            Me.gbBlattformat = New System.Windows.Forms.GroupBox()
            Me.rbDinA4 = New System.Windows.Forms.RadioButton()
            Me.rbDinA3 = New System.Windows.Forms.RadioButton()
            Me.rbDinA2 = New System.Windows.Forms.RadioButton()
            Me.rbDinA1 = New System.Windows.Forms.RadioButton()
            Me.rbDinA0 = New System.Windows.Forms.RadioButton()
            Me.TextBox2 = New System.Windows.Forms.TextBox()
            Me.TextBox1 = New System.Windows.Forms.TextBox()
            Me.Label9 = New System.Windows.Forms.Label()
            Me.Label8 = New System.Windows.Forms.Label()
            Me.Label7 = New System.Windows.Forms.Label()
            Me.Label6 = New System.Windows.Forms.Label()
            Me.Label5 = New System.Windows.Forms.Label()
            Me.Label4 = New System.Windows.Forms.Label()
            Me.Label3 = New System.Windows.Forms.Label()
            Me.gbAuswahl = New System.Windows.Forms.GroupBox()
            Me.cboAuswahl = New System.Windows.Forms.ComboBox()
            Me.lblAuswahlTxt = New System.Windows.Forms.Label()
            Me.Label2 = New System.Windows.Forms.Label()
            Me.Label1 = New System.Windows.Forms.Label()
            Me.gbEingabe = New System.Windows.Forms.GroupBox()
            Me.gbOrientierung.SuspendLayout()
            Me.gbBlattformat.SuspendLayout()
            Me.gbAuswahl.SuspendLayout()
            Me.gbEingabe.SuspendLayout()
            Me.SuspendLayout()
            'TextBox6
            Me.TextBox6.Location = New System.Drawing.Point(144, 191)
            Me.TextBox6.Name = "TextBox6"
            Me.TextBox6.Size = New System.Drawing.Size(208, 20)
            Me.TextBox6.TabIndex = 14
            Me.TextBox6.Tag = "Gewicht"
            'lblQuer
            Me.lblQuer.BorderStyle = System.Windows.Forms.BorderStyle.FixedSingle
            Me.lblQuer.Font = New System.Drawing.Font("Microsoft Sans Serif", 14.25!, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, CType(0, Byte))
            Me.lblQuer.Location = New System.Drawing.Point(114, 75)
            Me.lblQuer.Name = "lblQuer"
            Me.lblQuer.Size = New System.Drawing.Size(32, 26)
            Me.lblQuer.TabIndex = 3
            Me.lblQuer.Text = "A"
            Me.lblQuer.TextAlign = System.Drawing.ContentAlignment.MiddleCenter
            'lblHoch
            Me.lblHoch.BorderStyle = System.Windows.Forms.BorderStyle.FixedSingle
            Me.lblHoch.Font = New System.Drawing.Font("Microsoft Sans Serif", 14.25!, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, CType(0, Byte))
            Me.lblHoch.Location = New System.Drawing.Point(114, 25)
            Me.lblHoch.Name = "lblHoch"
            Me.lblHoch.Size = New System.Drawing.Size(26, 32)
            Me.lblHoch.TabIndex = 2
            Me.lblHoch.Text = "A"
            Me.lblHoch.TextAlign = System.Drawing.ContentAlignment.MiddleCenter
            'rbQuer
            Me.rbQuer.AutoSize = True
            Me.rbQuer.Location = New System.Drawing.Point(6, 82)
            Me.rbQuer.Name = "rbQuer"
            Me.rbQuer.Size = New System.Drawing.Size(31, 17)
            Me.rbQuer.TabIndex = 1
            Me.rbQuer.TabStop = True
            Me.rbQuer.Text = "q"
            Me.rbQuer.UseVisualStyleBackColor = True
            'cboBearbeiter
            Me.cboBearbeiter.FormattingEnabled = True
            Me.cboBearbeiter.Location = New System.Drawing.Point(144, 23)
            Me.cboBearbeiter.Name = "cboBearbeiter"
            Me.cboBearbeiter.Size = New System.Drawing.Size(208, 21)
            Me.cboBearbeiter.TabIndex = 20
            Me.cboBearbeiter.Tag = "Bearb-Name"
            'Label0
            Me.Label0.AutoSize = True
            Me.Label0.Location = New System.Drawing.Point(15, 26)
            Me.Label0.Name = "Label0"
            Me.Label0.Size = New System.Drawing.Size(39, 13)
            Me.Label0.TabIndex = 19
            Me.Label0.Text = "Label0"
            'Label10
            Me.Label10.AutoSize = True
            Me.Label10.Location = New System.Drawing.Point(358, 194)
            Me.Label10.Name = "Label10"
            Me.Label10.Size = New System.Drawing.Size(27, 13)
            Me.Label10.TabIndex = 18
            Me.Label10.Text = "bl10"
            'TextBox0
            Me.TextBox0.Location = New System.Drawing.Point(144, 47)
            Me.TextBox0.Name = "TextBox0"
            Me.TextBox0.Size = New System.Drawing.Size(208, 20)
            Me.TextBox0.TabIndex = 17
            Me.TextBox0.Tag = "Bearb-Datum"
            'TextBox8
            Me.TextBox8.Location = New System.Drawing.Point(144, 239)
            Me.TextBox8.Name = "TextBox8"
            Me.TextBox8.Size = New System.Drawing.Size(208, 20)
            Me.TextBox8.TabIndex = 16
            Me.TextBox8.Tag = "Toleranz"
            'TextBox5
            Me.TextBox5.Location = New System.Drawing.Point(144, 167)
            Me.TextBox5.Name = "TextBox5"
            Me.TextBox5.Size = New System.Drawing.Size(208, 20)
            Me.TextBox5.TabIndex = 13
            Me.TextBox5.Tag = "Maßstab2"
            'rbHoch
            Me.rbHoch.AutoSize = True
            Me.rbHoch.Location = New System.Drawing.Point(6, 30)
            Me.rbHoch.Name = "rbHoch"
            Me.rbHoch.Size = New System.Drawing.Size(31, 17)
            Me.rbHoch.TabIndex = 0
            Me.rbHoch.TabStop = True
            Me.rbHoch.Text = "h"
            Me.rbHoch.UseVisualStyleBackColor = True
            'TextBox7
            Me.TextBox7.Location = New System.Drawing.Point(144, 215)
            Me.TextBox7.Name = "TextBox7"
            Me.TextBox7.Size = New System.Drawing.Size(208, 20)
            Me.TextBox7.TabIndex = 15
            Me.TextBox7.Tag = "Jahr"
            'gbOrientierung
            Me.gbOrientierung.Controls.Add(Me.lblQuer)
            Me.gbOrientierung.Controls.Add(Me.lblHoch)
            Me.gbOrientierung.Controls.Add(Me.rbQuer)
            Me.gbOrientierung.Controls.Add(Me.rbHoch)
            Me.gbOrientierung.Location = New System.Drawing.Point(218, 14)
            Me.gbOrientierung.Name = "gbOrientierung"
            Me.gbOrientierung.Size = New System.Drawing.Size(162, 168)
            Me.gbOrientierung.TabIndex = 14
            Me.gbOrientierung.TabStop = False
            Me.gbOrientierung.Text = "GroupBox2"
            'lblTmpFileName
            Me.lblTmpFileName.AutoSize = True
            Me.lblTmpFileName.Location = New System.Drawing.Point(174, 551)
            Me.lblTmpFileName.Name = "lblTmpFileName"
            Me.lblTmpFileName.Size = New System.Drawing.Size(82, 13)
            Me.lblTmpFileName.TabIndex = 13
            Me.lblTmpFileName.Text = "lblTmpFileName"
            'btnCancel
            Me.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel
            Me.btnCancel.Location = New System.Drawing.Point(93, 546)
            Me.btnCancel.Name = "btnCancel"
            Me.btnCancel.Size = New System.Drawing.Size(75, 23)
            Me.btnCancel.TabIndex = 12
            Me.btnCancel.Text = "abbrechen"
            Me.btnCancel.UseVisualStyleBackColor = True
            'btnOK
            Me.btnOK.Location = New System.Drawing.Point(12, 546)
            Me.btnOK.Name = "btnOK"
            Me.btnOK.Size = New System.Drawing.Size(75, 23)
            Me.btnOK.TabIndex = 11
            Me.btnOK.Text = "ok"
            Me.btnOK.UseVisualStyleBackColor = True
            'TextBox4
            Me.TextBox4.Location = New System.Drawing.Point(144, 143)
            Me.TextBox4.Name = "TextBox4"
            Me.TextBox4.Size = New System.Drawing.Size(208, 20)
            Me.TextBox4.TabIndex = 12
            Me.TextBox4.Tag = "Werkstoff"
            'btnInfo
            Me.btnInfo.Image = CType(resources.GetObject("btnInfo.Image"), System.Drawing.Image)
            Me.btnInfo.Location = New System.Drawing.Point(411, 1)
            Me.btnInfo.Name = "btnInfo"
            Me.btnInfo.Size = New System.Drawing.Size(24, 24)
            Me.btnInfo.TabIndex = 15
            Me.btnInfo.UseVisualStyleBackColor = True
            'TextBox3
            Me.TextBox3.Location = New System.Drawing.Point(144, 119)
            Me.TextBox3.Name = "TextBox3"
            Me.TextBox3.Size = New System.Drawing.Size(208, 20)
            Me.TextBox3.TabIndex = 11
            Me.TextBox3.Tag = "Fremdzeichnungsnummer"
            'gbBlattformat
            Me.gbBlattformat.Controls.Add(Me.rbDinA4)
            Me.gbBlattformat.Controls.Add(Me.rbDinA3)
            Me.gbBlattformat.Controls.Add(Me.rbDinA2)
            Me.gbBlattformat.Controls.Add(Me.rbDinA1)
            Me.gbBlattformat.Controls.Add(Me.rbDinA0)
            Me.gbBlattformat.Location = New System.Drawing.Point(12, 12)
            Me.gbBlattformat.Name = "gbBlattformat"
            Me.gbBlattformat.Size = New System.Drawing.Size(200, 170)
            Me.gbBlattformat.TabIndex = 8
            Me.gbBlattformat.TabStop = False
            Me.gbBlattformat.Text = "GroupBox1"
            'rbDinA4
            Me.rbDinA4.AutoSize = True
            Me.rbDinA4.Location = New System.Drawing.Point(22, 135)
            Me.rbDinA4.Name = "rbDinA4"
            Me.rbDinA4.Size = New System.Drawing.Size(90, 17)
            Me.rbDinA4.TabIndex = 4
            Me.rbDinA4.TabStop = True
            Me.rbDinA4.Text = "RadioButton5"
            Me.rbDinA4.UseVisualStyleBackColor = True
            'rbDinA3
            Me.rbDinA3.AutoSize = True
            Me.rbDinA3.Location = New System.Drawing.Point(22, 107)
            Me.rbDinA3.Name = "rbDinA3"
            Me.rbDinA3.Size = New System.Drawing.Size(90, 17)
            Me.rbDinA3.TabIndex = 3
            Me.rbDinA3.TabStop = True
            Me.rbDinA3.Text = "RadioButton4"
            Me.rbDinA3.UseVisualStyleBackColor = True
            'rbDinA2
            Me.rbDinA2.AutoSize = True
            Me.rbDinA2.Location = New System.Drawing.Point(22, 79)
            Me.rbDinA2.Name = "rbDinA2"
            Me.rbDinA2.Size = New System.Drawing.Size(90, 17)
            Me.rbDinA2.TabIndex = 2
            Me.rbDinA2.TabStop = True
            Me.rbDinA2.Text = "RadioButton3"
            Me.rbDinA2.UseVisualStyleBackColor = True
            'rbDinA1
            Me.rbDinA1.AutoSize = True
            Me.rbDinA1.Location = New System.Drawing.Point(22, 51)
            Me.rbDinA1.Name = "rbDinA1"
            Me.rbDinA1.Size = New System.Drawing.Size(90, 17)
            Me.rbDinA1.TabIndex = 1
            Me.rbDinA1.TabStop = True
            Me.rbDinA1.Text = "RadioButton2"
            Me.rbDinA1.UseVisualStyleBackColor = True
            'rbDinA0
            Me.rbDinA0.AutoSize = True
            Me.rbDinA0.Location = New System.Drawing.Point(22, 23)
            Me.rbDinA0.Name = "rbDinA0"
            Me.rbDinA0.Size = New System.Drawing.Size(90, 17)
            Me.rbDinA0.TabIndex = 0
            Me.rbDinA0.TabStop = True
            Me.rbDinA0.Text = "RadioButton1"
            Me.rbDinA0.UseVisualStyleBackColor = True
            'TextBox2
            Me.TextBox2.Location = New System.Drawing.Point(144, 95)
            Me.TextBox2.Name = "TextBox2"
            Me.TextBox2.Size = New System.Drawing.Size(208, 20)
            Me.TextBox2.TabIndex = 10
            Me.TextBox2.Tag = "Ursprung"
            'TextBox1
            Me.TextBox1.Location = New System.Drawing.Point(144, 71)
            Me.TextBox1.Name = "TextBox1"
            Me.TextBox1.Size = New System.Drawing.Size(208, 20)
            Me.TextBox1.TabIndex = 9
            Me.TextBox1.Tag = "Maßstab"
            'Label9
            Me.Label9.AutoSize = True
            Me.Label9.Location = New System.Drawing.Point(13, 242)
            Me.Label9.Name = "Label9"
            Me.Label9.Size = New System.Drawing.Size(39, 13)
            Me.Label9.TabIndex = 8
            Me.Label9.Text = "Label9"
            'Label8
            Me.Label8.AutoSize = True
            Me.Label8.Location = New System.Drawing.Point(15, 218)
            Me.Label8.Name = "Label8"
            Me.Label8.Size = New System.Drawing.Size(39, 13)
            Me.Label8.TabIndex = 7
            Me.Label8.Text = "Label8"
            'Label7
            Me.Label7.AutoSize = True
            Me.Label7.Location = New System.Drawing.Point(15, 194)
            Me.Label7.Name = "Label7"
            Me.Label7.Size = New System.Drawing.Size(39, 13)
            Me.Label7.TabIndex = 6
            Me.Label7.Text = "Label7"
            'Label6
            Me.Label6.AutoSize = True
            Me.Label6.Location = New System.Drawing.Point(15, 170)
            Me.Label6.Name = "Label6"
            Me.Label6.Size = New System.Drawing.Size(39, 13)
            Me.Label6.TabIndex = 5
            Me.Label6.Text = "Label6"
            'Label5
            Me.Label5.AutoSize = True
            Me.Label5.Location = New System.Drawing.Point(15, 146)
            Me.Label5.Name = "Label5"
            Me.Label5.Size = New System.Drawing.Size(39, 13)
            Me.Label5.TabIndex = 4
            Me.Label5.Text = "Label5"
            'Label4
            Me.Label4.AutoSize = True
            Me.Label4.Location = New System.Drawing.Point(15, 122)
            Me.Label4.Name = "Label4"
            Me.Label4.Size = New System.Drawing.Size(39, 13)
            Me.Label4.TabIndex = 3
            Me.Label4.Text = "Label4"
            'Label3
            Me.Label3.AutoSize = True
            Me.Label3.Location = New System.Drawing.Point(15, 98)
            Me.Label3.Name = "Label3"
            Me.Label3.Size = New System.Drawing.Size(39, 13)
            Me.Label3.TabIndex = 2
            Me.Label3.Text = "Label3"
            'gbAuswahl
            Me.gbAuswahl.Controls.Add(Me.cboAuswahl)
            Me.gbAuswahl.Controls.Add(Me.lblAuswahlTxt)
            Me.gbAuswahl.Location = New System.Drawing.Point(12, 188)
            Me.gbAuswahl.Name = "gbAuswahl"
            Me.gbAuswahl.Size = New System.Drawing.Size(413, 77)
            Me.gbAuswahl.TabIndex = 9
            Me.gbAuswahl.TabStop = False
            Me.gbAuswahl.Text = "GroupBox1"
            'cboAuswahl
            Me.cboAuswahl.FormattingEnabled = True
            Me.cboAuswahl.Location = New System.Drawing.Point(14, 39)
            Me.cboAuswahl.Name = "cboAuswahl"
            Me.cboAuswahl.Size = New System.Drawing.Size(258, 21)
            Me.cboAuswahl.TabIndex = 1
            'lblAuswahlTxt
            Me.lblAuswahlTxt.AutoSize = True
            Me.lblAuswahlTxt.Location = New System.Drawing.Point(11, 23)
            Me.lblAuswahlTxt.Name = "lblAuswahlTxt"
            Me.lblAuswahlTxt.Size = New System.Drawing.Size(94, 13)
            Me.lblAuswahlTxt.TabIndex = 0
            Me.lblAuswahlTxt.Text = "Schriftfeld wählen!"
            'Label2
            Me.Label2.AutoSize = True
            Me.Label2.Location = New System.Drawing.Point(15, 74)
            Me.Label2.Name = "Label2"
            Me.Label2.Size = New System.Drawing.Size(39, 13)
            Me.Label2.TabIndex = 1
            Me.Label2.Text = "Label2"
            'Label1
            Me.Label1.AutoSize = True
            Me.Label1.Location = New System.Drawing.Point(15, 50)
            Me.Label1.Name = "Label1"
            Me.Label1.Size = New System.Drawing.Size(39, 13)
            Me.Label1.TabIndex = 0
            Me.Label1.Text = "Label1"
            'gbEingabe
            Me.gbEingabe.Controls.Add(Me.cboBearbeiter)
            Me.gbEingabe.Controls.Add(Me.Label0)
            Me.gbEingabe.Controls.Add(Me.Label10)
            Me.gbEingabe.Controls.Add(Me.TextBox0)
            Me.gbEingabe.Controls.Add(Me.TextBox8)
            Me.gbEingabe.Controls.Add(Me.TextBox7)
            Me.gbEingabe.Controls.Add(Me.TextBox6)
            Me.gbEingabe.Controls.Add(Me.TextBox5)
            Me.gbEingabe.Controls.Add(Me.TextBox4)
            Me.gbEingabe.Controls.Add(Me.TextBox3)
            Me.gbEingabe.Controls.Add(Me.TextBox2)
            Me.gbEingabe.Controls.Add(Me.TextBox1)
            Me.gbEingabe.Controls.Add(Me.Label9)
            Me.gbEingabe.Controls.Add(Me.Label8)
            Me.gbEingabe.Controls.Add(Me.Label7)
            Me.gbEingabe.Controls.Add(Me.Label6)
            Me.gbEingabe.Controls.Add(Me.Label5)
            Me.gbEingabe.Controls.Add(Me.Label4)
            Me.gbEingabe.Controls.Add(Me.Label3)
            Me.gbEingabe.Controls.Add(Me.Label2)
            Me.gbEingabe.Controls.Add(Me.Label1)
            Me.gbEingabe.Location = New System.Drawing.Point(12, 271)
            Me.gbEingabe.Name = "gbEingabe"
            Me.gbEingabe.Size = New System.Drawing.Size(413, 269)
            Me.gbEingabe.TabIndex = 10
            Me.gbEingabe.TabStop = False
            Me.gbEingabe.Text = "GroupBox1"
            'FrmStart
            Me.ClientSize = New System.Drawing.Size(438, 584)
            Me.Controls.Add(Me.gbOrientierung)
            Me.Controls.Add(Me.lblTmpFileName)
            Me.Controls.Add(Me.btnCancel)
            Me.Controls.Add(Me.btnOK)
            Me.Controls.Add(Me.btnInfo)
            Me.Controls.Add(Me.gbBlattformat)
            Me.Controls.Add(Me.gbAuswahl)
            Me.Controls.Add(Me.gbEingabe)
            Me.Icon = CType(resources.GetObject("$this.Icon"), System.Drawing.Icon)
            Me.Name = "FrmStart"
            Me.gbOrientierung.ResumeLayout(False)
            Me.gbOrientierung.PerformLayout()
            Me.gbBlattformat.ResumeLayout(False)
            Me.gbBlattformat.PerformLayout()
            Me.gbAuswahl.ResumeLayout(False)
            Me.gbAuswahl.PerformLayout()
            Me.gbEingabe.ResumeLayout(False)
            Me.gbEingabe.PerformLayout()
            Me.ResumeLayout(False)
            Me.PerformLayout()
        End Sub
#End Region
    End Class
End Namespace
Code Of "StandardAddInServer"
Imports Inventor
Imports Microsoft.Win32
    <ProgIdAttribute("myInvDrwEvents.StandardAddInServer"), _
    GuidAttribute("60d67787-5c1b-4a5f-9e4e-c1086ee6262c")> _
    Public Class StandardAddInServer
        Implements Inventor.ApplicationAddInServer
        Private WithEvents m_uiEvents As UserInterfaceEvents
        'Private WithEvents m_sampleButton As ButtonDefinition
        ' Inventor application object.
        Private g_inventorApplication As Inventor.Application
        Private WithEvents m_DocEvents As DocumentEvents
        Private WithEvents m_AppEvents As ApplicationEvents
#Region "ApplicationAddInServer Members"
        ' This method is called by Inventor when it loads the AddIn. The AddInSiteObject provides access
        ' to the Inventor Application object. The FirstTime flag indicates if the AddIn is loaded for
        ' the first time. However, with the introduction of the ribbon this argument is always true.
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal FirstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' Initialize AddIn members.
            g_inventorApplication = addInSiteObject.Application
            ' Connect to the user-interface events to handle a ribbon reset.
            m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
            ' TODO: Add button definitions.
            ' Sample to illustrate creating a button definition.
            'Dim largeIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.YourBigImage)
            'Dim smallIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.YourSmallImage)
            'Dim controlDefs As Inventor.ControlDefinitions = g_inventorApplication.CommandManager.ControlDefinitions
            'm_sampleButton = controlDefs.AddButtonDefinition("Command Name", "Internal Name", CommandTypesEnum.kShapeEditCmdType, AddInClientID)
            ' Add to the user interface, if it's the first time.
            'If FirstTime Then
            '    AddToUserInterface()
            'End If
            m_AppEvents = g_inventorApplication.ApplicationEvents
            'Windows.Forms.MessageBox.Show("ApplicationAddInServer - Activate", "Ende", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Information)
        End Sub
        ' This method is called by Inventor when the AddIn is unloaded. The AddIn will be
        ' unloaded either manually by the user or when the Inventor session is terminated.
        Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
            ' TODO:  Add ApplicationAddInServer.Deactivate implementation
            ' Release objects.
            m_uiEvents = Nothing
            g_inventorApplication = Nothing
            'System.GC.Collect()
            System.GC.WaitForPendingFinalizers()
        End Sub
        ' This property is provided to allow the AddIn to expose an API of its own to other
        ' programs. Typically, this  would be done by implementing the AddIn's API
        ' interface in a class and returning that class object through this property.
        Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation
            Get
                Return Nothing
            End Get
        End Property
        ' Note:this method is now obsolete, you should use the
        ' ControlDefinition functionality for implementing commands.
        Public Sub ExecuteCommand(ByVal CommandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand
        End Sub
#End Region
#Region "User interface definition"
        ' Sub where the user-interface creation is done.  This is called when
        ' the add-in loaded and also if the user interface is reset.
        Private Shared Sub AddToUserInterface()
            ' This is where you'll add code to add buttons to the ribbon.
            '** Sample to illustrate creating a button on a new panel of the Tools tab of the Part ribbon.
            '' Get the part ribbon.
            'Dim partRibbon As Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item("Part")
            '' Get the "Tools" tab.
            'Dim toolsTab As RibbonTab = partRibbon.RibbonTabs.Item("id_TabTools")
            '' Create a new panel.
            'Dim customPanel As RibbonPanel = toolsTab.RibbonPanels.Add("Sample", "MysSample", AddInClientID)
            '' Add a button.
            'customPanel.CommandControls.AddButton(m_sampleButton)
        End Sub
        Private Sub m_uiEvents_OnResetRibbonInterface(Context As NameValueMap) Handles m_uiEvents.OnResetRibbonInterface
            ' The ribbon was reset, so add back the add-ins user-interface.
        End Sub
        ' Sample handler for the button.
        'Private Sub m_sampleButton_OnExecute(Context As NameValueMap) Handles m_sampleButton.OnExecute
        '    MsgBox("Button was clicked.")
        'End Sub
        Private Sub m_AppEvents_OnNewDocument(DocumentObject As Inventor._Document, BeforeOrAfter As Inventor.EventTimingEnum, Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_AppEvents.OnNewDocument
            Dim strTFN As String = ""
            '            Windows.Forms.MessageBox.Show(DocumentObject.DisplayName & " - Start", "m_AppEvents_OnNewDocument", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Information)
            For i As Long = 1 To Context.Count
                If Context.Name(i) = "TemplateFileName" Then
                    strTFN = System.IO.Path.GetFileName(Context.Value(Context.Name(i)).ToString)
                End If
            Next
            Select Case BeforeOrAfter
                Case EventTimingEnum.kBefore
                    'MessageBox.Show("Case Before: ")
                Case EventTimingEnum.kAfter
                    If DocumentObject.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
                        '                        Windows.Forms.MessageBox.Show("Case kAfter: ", "m_AppEvents_OnNewDocument", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Information)
                        Try
                            '                            Windows.Forms.MessageBox.Show("Before frmStart.Show()", "m_AppEvents_OnNewDocument", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Information)
                            Dim oForm As New FrmStart
                            oForm.lblTmpFileName.Text = strTFN
                            oForm.Show()
                            Windows.Forms.MessageBox.Show(ex.Message, "m_AppEvents_OnNewDocument", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Warning)
                        End Try
                    End If
                Case Else
                    'no action
            End Select
            '            Windows.Forms.MessageBox.Show(DocumentObject.DisplayName & " - Ende", "m_AppEvents_OnNewDocument", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Information)
        End Sub
        Private Sub m_AppEvents_OnActivateDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum,
            ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_AppEvents.OnActivateDocument
            m_DocEvents = DocumentObject.DocumentEvents
            If BeforeOrAfter <> EventTimingEnum.kAfter Then
                Exit Sub
            End If
            '            Windows.Forms.MessageBox.Show(DocumentObject.DisplayName, "OnActivateDocument VB - WithEvents", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Information)
        End Sub
        Private Sub m_DocEvents_OnActivate(BeforeOrAfter As Inventor.EventTimingEnum, Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_DocEvents.OnActivate
            'Dim oApp As Inventor.Application
            'oApp = Marshal.GetActiveObject("Inventor.Application")
            'If BeforeOrAfter <> EventTimingEnum.kAfter Then
            '    Exit Sub
            'End If
            'Select Case oApp.ActiveDocumentType
            '    Case DocumentTypeEnum.kDrawingDocumentObject
            '        MessageBox.Show("Hallo ich bin eine idw!")
            '    Case DocumentTypeEnum.kAssemblyDocumentObject
            '        MessageBox.Show("Hallo ich bin eine iam!")
            '    Case DocumentTypeEnum.kPartDocumentObject
            '        MessageBox.Show("Hallo ich bin eine ipt!")
            '    Case Else
            '        MessageBox.Show("Hallo ich weiss nicht was ich bin!")
            'End Select
            'oApp = Nothing
        End Sub
        Private Sub m_DocEvents_OnSave(BeforeOrAfter As Inventor.EventTimingEnum, Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_DocEvents.OnSave
            If oApp.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
                    Case EventTimingEnum.kBefore     'Event fired BEFORE native processing.
                        'MsgBox("VOR dem Speichern: irgendetwas machen", vbInformation, "AppEvent")
                        Call WriteScalesToTitleblock()
                        Call UpdateIndexes()
                        oApp.StatusBarText = "myInvDrwEvents: vor dem Speichern --> WriteScalesToTitleblock; UpdateIndexes"
                    Case EventTimingEnum.kAfter 'Event fired AFTER native processing.
                        'MsgBox("NACH dem Speichern: irgendetwas anderes machen", vbInformation, "AppEvent")
                        oApp.StatusBarText = "myInvDrwEvents: nach dem Speichern --> derzeit keine Aktionen"
                    Case EventTimingEnum.kAbort 'Event fired if the native processing ABORTED
                        'MsgBox("Speichervorgang abgebrochen", vbInformation, "AppEvent")
                        oApp.StatusBarText = "myInvDrwEvents: Speichern abgebrochen --> WriteScalesToTitleblock; UpdateIndexes"
                End Select
            End If
            oApp = Nothing
        End Sub
        Shared Sub UpdateIndexes()
            Dim oDoc As Document
            Dim oSkdSym As SketchedSymbol, oTxtBox As Inventor.TextBox, sIndex As String = ""
            'Objekt herstellen
            oDoc = oApp.ActiveDocument
            'Funktioniert nur, wenn Drawing und mindestens eine Ansicht vorhanden ist:
            If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
            If oDoc.ActiveSheet.DrawingViews.Count = 0 Then Exit Sub
            For Each oSkdSym In oDoc.ActiveSheet.SketchedSymbols
                With oSkdSym
                    If .Name = "Index" Then
                        For Each oTxtBox In .Definition.Sketch.TextBoxes
                            If Len(oTxtBox.Text) = 2 Then
                                'Debug.Print oSkdSym.GetResultText(oTxtBox)
                                If .GetResultText(oTxtBox) > sIndex Then sIndex = .GetResultText(oTxtBox)
                            End If
                        Next
                    End If
                End With
            Next
            oDoc.PropertySets.Item("Design Tracking - Eigenschaften").Item("User Status").Value = sIndex
            oDoc.Update()
            oTxtBox = Nothing
            oSkdSym = Nothing
            oDoc = Nothing
            oApp = Nothing
        End Sub
        Shared Sub WriteScalesToTitleblock()
            Dim i, j, k As Integer
            Dim dblMainScale As Double, dblMoreScales As Double, dblSiteScales(10) As Double
            Dim sMainScale As String, sMoreScales As String
            'Objekt herstellen
            'Ermittle die Hauptansicht und Hauptmaßstab
            dblMainScale = oDoc.ActiveSheet.DrawingViews(1).Scale
            'Ermittle weitere Ansichten
            j = 0
            For i = 1 To oDoc.ActiveSheet.DrawingViews.Count
                'Ermittle weitere Maßstäbe
                dblMoreScales = oDoc.ActiveSheet.DrawingViews(i).Scale
                'Prüfe, ob gleich hauptmaßstab
                If dblMoreScales <> dblMainScale Then
                    'Prüfe, ob schon als Nebenmaßstab vorhanden
                    If j > 0 Then
                        For k = 0 To j
                            If dblMoreScales = dblSiteScales(k) Then
                                dblMoreScales = 0
                                Exit For
                            End If
                        Next k
                    End If
                    If dblMoreScales <> 0 Then
                        'Nimm in die Liste auf
                        dblSiteScales(j) = dblMoreScales
                        j = j + 1
                        'Die liste ist begrenzt...
                        If j = 11 Then Exit For
                    End If
                End If
            Next i
            'Grundmasstab setzen
            sMainScale = EE_FormatScale(dblMainScale)
            'weitere Massstäbe setzen
            sMoreScales = ""
            If j > 0 Then
                For i = 0 To j - 1
                    sMoreScales = sMoreScales + EE_FormatScale(dblSiteScales(i))
                    If Not i = j - 1 Then sMoreScales = sMoreScales + ","
                Next i
                sMoreScales = "(" + sMoreScales + ")"
                sMoreScales = Replace(sMoreScales, ",", ", ", 1, -1, vbTextCompare)
            End If
            Call WriteToTextBox("<Maßstab>", sMainScale)
            Call WriteToTextBox("<weitere Maßstäbe>", sMoreScales)
            oDoc = Nothing
            oApp = Nothing
        End Sub
        Private Shared Function EE_FormatScale(ByVal S As Double) As String
            If S >= 1 Then
                If (10 * S Mod 10) = 0 Then
                    EE_FormatScale = Format(S, "0") + ":1"
                Else
                    EE_FormatScale = Format(S, "0.0") + ":1"
                End If
            Else
                If (10 * (1 / S) Mod 10) = 0 Then
                    EE_FormatScale = "1:" + Format(1 / S, "0")
                Else
                    EE_FormatScale = "1:" + Format(1 / S, "0.0")
                End If
            End If
        End Function
        Shared Sub WriteToTextBox(sTBname As String, sTBvalue As String)
            Dim oDoc As Document, oTB As TitleBlock, oTxtBox As Inventor.TextBox
            oTB = oDoc.Sheets(1).TitleBlock
            For Each oTxtBox In oTB.Definition.Sketch.TextBoxes
                If oTxtBox.Text = sTBname Then
                    Call oTB.SetPromptResultText(oTxtBox, sTBvalue)
                    Exit For
                End If
            Next oTxtBox
            oTxtBox = Nothing
            oTB = Nothing
            oDoc = Nothing
            oApp = Nothing
        End Sub
#End Region
    End Class
End Namespace
Public Module Globals
    Public g_inventorApplication As Inventor.Application
#Region "Function to get the add-in client ID."
    ' This function uses reflection to get the GuidAttribute associated with the add-in.
    Public Function AddInClientID() As String
        Dim guid As String = ""
        Try
            Dim t As Type = GetType(myInvDrwEvents.StandardAddInServer)
            Dim customAttributes() As Object = t.GetCustomAttributes(GetType(GuidAttribute), False)
            Dim guidAttribute As GuidAttribute = CType(customAttributes(0), GuidAttribute)
            guid = "{" + guidAttribute.Value.ToString() + "}"
        End Try
        Return guid
    End Function
#End Region
#Region "hWnd Wrapper Class"
    ' This class is used to wrap a Win32 hWnd as a .Net IWind32Window class.
    ' This is primarily used for parenting a dialog to the Inventor window.
    ' For example:
    ' myForm.Show(New WindowWrapper(g_inventorApplication.MainFrameHWND))
    Public Class WindowWrapper
        Implements System.Windows.Forms.IWin32Window
        Public Sub New(ByVal handle As IntPtr)
            _hwnd = handle
        End Sub
        Public ReadOnly Property Handle() As IntPtr _
          Implements System.Windows.Forms.IWin32Window.Handle
            Get
                Return _hwnd
            End Get
        End Property
        Private _hwnd As IntPtr
    End Class
#End Region
#Region "Image Converter"
    ' Class used to convert bitmaps and icons from their .Net native types into
    ' an IPictureDisp object which is what the Inventor API requires. A typical
    ' usage is shown below where MyIcon is a bitmap or icon that's available
    ' as a resource of the project.
    ' Dim smallIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.MyIcon)
    Public NotInheritable Class PictureDispConverter
        <DllImport("OleAut32.dll", EntryPoint:="OleCreatePictureIndirect", ExactSpelling:=True, PreserveSig:=False)>
        Private Shared Function OleCreatePictureIndirect(
            <MarshalAs(UnmanagedType.AsAny)> ByVal picdesc As Object,
            ByRef iid As Guid,
            <MarshalAs(UnmanagedType.Bool)> ByVal fOwn As Boolean) As stdole.IPictureDisp
        End Function
        Shared iPictureDispGuid As Guid = GetType(stdole.IPictureDisp).GUID
        Private NotInheritable Class PICTDESC
            Private Sub New()
            End Sub
            'Picture Types
            Public Const PICTYPE_BITMAP As Short = 1
            Public Const PICTYPE_ICON As Short = 3
            <StructLayout(LayoutKind.Sequential)> _
            Public Class Icon
                Friend cbSizeOfStruct As Integer = Marshal.SizeOf(GetType(PICTDESC.Icon))
                Friend picType As Integer = PICTDESC.PICTYPE_ICON
                Friend hicon As IntPtr = IntPtr.Zero
                Friend unused1 As Integer
                Friend unused2 As Integer
                Friend Sub New(ByVal icon As System.Drawing.Icon)
                    Me.hicon = icon.ToBitmap().GetHicon()
                End Sub
            End Class
            Public Class Bitmap
                Friend cbSizeOfStruct As Integer = Marshal.SizeOf(GetType(PICTDESC.Bitmap))
                Friend picType As Integer = PICTDESC.PICTYPE_BITMAP
                Friend hbitmap As IntPtr = IntPtr.Zero
                Friend hpal As IntPtr = IntPtr.Zero
                Friend unused As Integer
                Friend Sub New(ByVal bitmap As System.Drawing.Bitmap)
                    Me.hbitmap = bitmap.GetHbitmap()
                End Sub
            End Class
        End Class
        Public Shared Function ToIPictureDisp(ByVal icon As System.Drawing.Icon) As stdole.IPictureDisp
            Dim pictIcon As New PICTDESC.Icon(icon)
            Return OleCreatePictureIndirect(pictIcon, iPictureDispGuid, True)
        End Function
        Public Shared Function ToIPictureDisp(ByVal bmp As System.Drawing.Bitmap) As stdole.IPictureDisp
            Dim pictBmp As New PICTDESC.Bitmap(bmp)
            Return OleCreatePictureIndirect(pictBmp, iPictureDispGuid, True)
        End Function
    End Class
#End Region
End Module
Message 11 of 18
bradeneuropeArthur
Try this:
                            oForm.ShowDialog() ' YOU USED SHOW
                        End Try
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 18
Ralph
thank you very much - this solved the problem.
Did you know why this problem occurs with frm.show?
Message 13 of 18
bradeneuropeArthur
Yes:
One is Modal
the other is Modeless
https://msdn.microsoft.com/en-us/Library/39wcs2dh(v=vs.100).aspx
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 18
Ralph
... ok - but why opens the space key the new file dialog?
Is there a shortcut for this within inventor or something like this?
Message 15 of 18
bradeneuropeArthur
I think SPACE means "Reuse last command"......
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 18
Ralph
it seem's you're right and then it's clear how it works in that way.
Once again - thank you very much for your support.
Ralph
Message 17 of 18
bradeneuropeArthur
Your thanks are appreciated!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 18
wilczek
but "ShowDialog" has the disadvantage that the dialog always remains in the foreground, which is still fine with "UserForm Open".
But I have programmed a form myself where the IProperties can be entered and I don't want the form to always be in the foreground so I have to use the ".Show" so how can I handle the problem with the space key?
