Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
[VB.NET] GET ACTIVE DOCUMENT
10 REPLIES 10
Message 1 of 11
tiago.tesche
618 Views, 10 Replies
tiago.tesche
Hello guys, i'm been trying to solve this question for a few days now and i could not get to a solution, every time i get this error when i try to get activedocument, i have others projects working on .net 4.7 that works, this project is .net 7.0, any ideias on how to overcome this? thx in advance.
Labels (1)
10 REPLIES 10
Message 2 of 11
bradeneuropeArthur
Change it to 4.7!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Change it to 4.7!
Arthur Knoors
Message 3 of 11
tiago.tesche
I tried but it does not have an option, there is another way to do it?
Message 4 of 11
bradeneuropeArthur
You need to install it
Arthur Knoors
Arthur Knoors
Message 5 of 11
https://www.google.com/url?sa=t&source=web&rct=j&url=https://dotnet.microsoft.com/en-us/download/dot...
Arthur Knoors
Arthur Knoors
Message 6 of 11
tiago.tesche
Yes, it's installed and i still don't get why it wouldn't work...
Message 7 of 11
bradeneuropeArthur
Is your code working now?
Arthur Knoors
Arthur Knoors
Message 8 of 11
tiago.tesche
No, i get the same error with multiples files... The only thing different from previous projects that i did is the framework, i can't think in something else. I guess i will use a later project as "template" for the new ones while a can't figure out whats happening. Besides setting reference to the Autodesk.Inventor.Interop theres another settings that i need to configure? thx Arthur.
Message 9 of 11
bradeneuropeArthur
Please upload the complete vb.net project and I will have a look!
Arthur Knoors
Arthur Knoors
Message 10 of 11
JelteDeJong
You created a .Net Core application. I think it will be very hard to change it back to a .Net Framework. Is it an option for you to recreate the project and select the correct project type from the start?
You can find some info on this topic in my tutorial about creating an Inventor addin. (See capter "Create a Visual Studio project")
Jelte de Jong
Blog: hjalte.nl - github.com
Jelte de Jong
Message 11 of 11
tiago.tesche
in reply to: JelteDeJong
tiago.tesche
that was my mistake i started a new project with .net framework and it  worked, thank you...
@bradeneuropeArthur  thanks fo your time!
