Using Multi-value list to do an appearance override of components
blandb
blandb
I have a multi-value list that I have created that has our standard colors in it. I have our company standard appearance library set. I just need to know how to select all components, minus fasteners and change the appearance of all the components for what my multi-value list has.
Any thoughts?
Autodesk Certified Professional
Replies (17)
bradeneuropeArthur
Within an assembly or how?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
blandb
Yea, it is from the assembly. Change all assembly occurrences. Except fasteners.
bradeneuropeArthur
Could you share the code or the multivalue list?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
blandb
MultiValue.SetList("PAINT", "paint color 1", "paint color 2", etc...)
This sets the multi-value parameter in the assembly to allow users to choose what color to pain the assembly.
dutt.thakar
@blandb
Are you looking for something like this?? Make sure you first type in the right asset library name in the below code and your paint colors must be contained within that library. The rule will only work for Part levels in Assembly it is not designed for sub levels. It will go through each part inside assembly which is not content center parts and change its color.
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oProjectMgr As DesignProjectManager = ThisApplication.DesignProjectManager
Dim LibraryPath As String = oProjectMgr.ActiveDesignProject.LibraryPaths.Item(1).Path
Dim CCPath As String = oProjectMgr.ActiveDesignProject.ContentCenterPath
Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library") 'Set which library you want to get your color from
Dim oApperance As Asset = assetLib.AppearanceAssets.Item(Parameter("PAINT"))
For Each oOcc In oDef.Occurrences
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject And oOcc.Definition.Document.FullFileName.Contains(CCPath) = False Then
		Dim oPdef As PartDocument = oOcc.Definition.Document
		oPdef.ActiveAppearance = oApperance
	End If
Next
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
blandb
I set the library as indicated, but I get this error.
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG)).
Also, since we don't switch appearance Libraries, Do I still need to Specify which to choose from, even though my library is set by default in the project?
dutt.thakar
@blandb
Yes please specify which library you are referring to.
Can you attach your assembly as ZIP if possible? Also, can you check the parameter name (Paint), and are you running the rule from the assembly?
I will try to see if something needs to be checked inside the assembly because I tested the rule in my assembly and it is working perfectly fine.
Dutt Thakar
LinkedIn
blandb
I have a parameter at the assembly level called "PAINT". This is being filled out by a multi-value setlist as mentioned below:
MultiValue.SetList("PAINT", "MED. BRONZE METALLIC", "STATUARY BRONZE", "CHAMPAGNE", "SANDSTONE",
						"POMPANO WHITE", "BIANCO", "JET BLACK", "GRAY", "ARGENTO 314 METALLIC", "ARGENTO 305 METALLIC")
Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("KANE Material Library") 'Set which library you want to get your color from
	End If
Next
dutt.thakar
@blandb
Can you upload your assembly if possible? also, can you try using the default library and a default color (i.e. Autodesk Appearance library and Color example : Yellow:)
Dutt Thakar
LinkedIn
blandb
Here is an example of scrap parts that I still get the same error with. Please see attached.
The "paint" rule sets the multi-value list and the "test" is where I am running the code you sent.
Thanks for your assistance.
dutt.thakar
@blandb
Thanks for providing the files, I have found two things one is that in your project settings it is not able to find Library path (the solution is to comment that line in code as it is not required).
The second and most important thing is, the names that you are adding as multi-value in "PAINT" parameter must exactly match with appearance name, I have observed that you have written "JET BLACK" only, whereas your appearance name is "JET BLACK P/N 17108P", please change your multivalue with exact names, Try below code where I have removed the library path line and, make sure you change your multi-value text same as appearance names.
As an example, a multivalue setlist should look like this
MultiValue.SetList("PAINT","STATUARY BRONZE P/N 17106P", "JET BLACK P/N 17108P")
 Updated rule,
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject 'And oOcc.Definition.Document.FullFileName.Contains(CCPath) = False Then
	End If
Next
Another bonus tip here, if you don't want to type in all the names exactly as they are in appearance in your "PAINT" multi-value parameter, try the below code, it actually captures all the appearance names in the active library and add them to the "PAINT" parameter multi-value list. Add it in a separate rule and you will see that all your appearance names will be added to the PAINT multi-value parameter list.
        Dim assetLib As AssetLibrary = ThisApplication.ActiveMaterialLibrary
        Dim Appearances As AssetsEnumerator = assetLib.AppearanceAssets
        Dim oList As New ArrayList
        For Each oAP As Asset In Appearances
            oList.Add(oAP.DisplayName)
        Next
	MultiValue.List("PAINT")=oList
Hope this is helpful.
Dutt Thakar
LinkedIn
blandb
I had a feeling these exact 2 point would come up. When I a pack and go of the test assembly, I may have had some items unchecked. But the actual file library is set as shown:
The other one about the names not matching is because we were looking at taking this assembly into forge, and I just wanted the customer to choose a color and not see the Part number associated with it. So, I had originally looked at a Select case that looked at the parameter "PAINT" then assigned the components an actual appearance with the correct names. So the partial name in the Multi-value set list is remnants of that. I hope that clarifies. If there is no way to go around without needing the part number with the paint, then I can add and it is no big deal.
dutt.thakar
@blandb
There is a workaround that you can do here, without changing the names in the PAINT parameter. Check the below rule and see if it works. Make sure that there should not be two appearances that contain the same name (e.g. "JET BLACK P/N 17108 P" and "JET BLACK P/N 16108 P" otherwise it will select the first it will find in the appearance list.
'Dim LibraryPath As String = oProjectMgr.ActiveDesignProject.LibraryPaths.Item(1).Path
Dim oAp As Asset
For Each oApperance As Asset In assetLib.AppearanceAssets
	If oApperance.DisplayName.Contains(Parameter("PAINT"))
		oAp  = oApperance
'Dim oApperance As Asset = assetLib.AppearanceAssets.Item(Parameter("PAINT"))
	End If
Next
	End If
Next
Dutt Thakar
LinkedIn
blandb
What you have is working, but as you say, the assemblies will not change, only ipt's will change.
Thanks for all your efforts.
dutt.thakar
@blandb  Yes, This is created for IPTs, You are welcome.
Please mark it as a solution if you are happy with it.
Dutt Thakar
LinkedIn
blandb
Maybe I am over simplifying this, but in my mind I had the rule the I assign out standard colors with which populates the user defined parameter with generic names.
Then my second rule would basically state:
Select Case PAINT
                Case “MED. BRONZE METALLIC”
               Component.Color("all current .iam’s, and parts except for content center fasteners and concrete slab with paint") = "MED. BRONZE METALLIC P/N 17109P"
                Case “STATUARY BRONZE”
               Component.Color("all current .iam’s, and parts except for content center fasteners and concrete slab with paint") = " STATUARY BRONZE..."
End select
Reason I need to just find the current components that exist in the assembly is because it is constantly changing. Swapping out panels, certain posts may exist and may not, etc.
I was going through trying to do a big if statement about if certain criteria is met, then basically just color override the components that exist. I figured there has to be a way to scan the assembly and just color override what is present.
thanks again.
I am not a super massive programmer, just know enough iLogic to get by.
blandb
Unfortunately, that didn't sole my issue.
Type a product name
