Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
toggle for planes on and off...
4 REPLIES 4
276 Views, 4 Replies
i'm sure everyone will laugh at this one but i use vbscripting quite often
because it's fairly easy and works with every program written for windows. i
have several scripts that do many things. rather than give them all away, i
thought maybe i'd give a sample and let everyone's imagination run... i use
this one to toggle my origin planes on and off. i know, baby stuff, but it
might help the novice programmer.
'VBScript Send Keys for Inventor
Set WshShell = WScript.CreateObject("WScript.Shell")
If WshShell.AppActivate("Autodesk Inventor") then
WshShell.SendKeys "%V"
WshShell.SendKeys "G"
WshShell.SendKeys "{ENTER}"
Else
wscript.quit
those newbies unfamiliar with this, just copy the code to notepad, saveas
"something.vbs", and place a shortcut on your taskbar for single-click
execution while in inventor.
Mark Bystry
Engineer
Ziggity Systems, Inc.
mbystry@ziggity.com
4 REPLIES 4
Hi Mark
Hey nothing wrong with that.
You really arent far from VBA though, the following does the same thing in
VBA.
Public Sub hideplanes()
SendKeys "%V"
SendKeys "G"
SendKeys "{ENTER}"
End Sub
Kent Keller
"Mark A. Bystry" wrote in message
news:97E9C9C45885E1D3AE68A45623EEFFF8@in.WebX.maYIadrTaRb...
i
i
use
> Else
> wscript.quit
> End If
> Mark Bystry
> Engineer
> mbystry@ziggity.com
thanks for your input, kent. one advantage of the script over vba is that
you cannot make custom icons in inventor like you can autocad/mdt. one could
either put the script on the taskbar or if you have office installed you can
add it to the microsoft shortcut bar. the latter works really great in
inventor. if you minimize the the shortcut bar to the windows caption bar,
in this case inventor's caption bar, you are able to see your icons. kind of
a workaround for not being able to make your own icons and macros.
Good points.
Drew did point me to this but I haven't tried it yet.
http://www.softwareutilities.com/
Actually I started playing around with making my own toolbar in VB but will
probably never do much with it.
Kent Keller
news:A8541AC6A499A62CC8AA5BE11BAF5890@in.WebX.maYIadrTaRb...
could
can
of
i've got a program called ezmacro. haven't used it much in the last year but
used to use it all the time. does some pretty nice things and can be used
with any program. you can record mouse clicks and keyboard entry and run it
back. hot keys can be set up also.
Technology Administrators
