Ole,
If you try to do the same thing manually in Inventor, you will see that
there is no way to specify which page (sheet) you want to use from the excel
file. Personnaly, I would no expect the API to do more than the app
itself...
However, you could probably use a trick in VB (e.g.: read the excel file
once, delete or move the first sheet and read the file again).
If you need help, I can try to give you a hand.
Marina
"Ole Germer"
a écrit dans le message news:
97BB3D51F8FA0CE1E92F0FF7959CCD52@in.WebX.maYIadrTaRb...
> Thanks for the help. I got everything on one page. It would have helped
if
> I could have two pages.
> Does Inventor ignore the second pages?
> Ole
> "Ole Germer" wrote in message
> news:50FD153451E5D7CBB0E378B218D63788@in.WebX.maYIadrTaRb...
> > I am trying to link a spread sheet to my parameter list. It is for a
> > involute approximation of a spline.
> > It is only the first sheet of a workbook that gets linked to inventor?
> > How do you copy data from the 2nd sheet in excell to the first sheet. I
> am
> > hoping that will work.
> > Ole
