This should be so simple but I can't get it accomplished. I have the code that copies the Drawing Resources in and then all I need is to add it to the active sheet. I have looked online and tried several different things but nothing works. The Title Block has prompted entries and is called ANSI A. Here is the code that I have.
Sub TitleBlockCopy()
Dim oSourceDocument As DrawingDocument
Set oSourceDocument = ThisApplication.ActiveDocument
' Open the template drawing to copy the title block from.
Dim oNewDocument As DrawingDocument
' if you put false here at the end it will not open visible, so you won't need to close it
Set oNewDocument = ThisApplication.Documents.Open("Q:\Inventor\Templates_v2014\Templates\part.idw", False)
' Get the new title block definition.
Dim oNewTitleBlockDef As TitleBlockDefinition
'make sure that in your template.idw the needed titleblock is active
Set oNewTitleBlockDef = oNewDocument.ActiveSheet.TitleBlock.Definition
' Set the new title block definition.
Dim oSourceTitleBlockDef As TitleBlockDefinition
Set oSourceTitleBlockDef = oNewTitleBlockDef.CopyTo(oSourceDocument)
' Iterate through the sheets.
Dim oSheet As Sheet
For Each oSheet In oSourceDocument.Sheets
oSheet.Activate
Dim oTitleBlock As TitleBlock
'THE BELOW LINE IS THE PART THAT I CAN'T GET TO WORK.
Set oTitleBlock = oSheet.AddTitleBlock("ANSI A")
Next
End Sub
Solved by MechMachineMan. Go to Solution.
Is the AddTitleBlock method throwing an error or does it just do nothing? Have you tried passing in the actual title block object rather than the string name?
I found your problem.
For a TB with 1 prompted entry:
Dim sPromptStrings(0) As String sPromptStrings(0) = ""
OR For 2:
Dim sPromptStrings(0 To 1) As String sPromptStrings(0) = "" sPromptStrings(1) = ""
Extrapolate this if it has more...
Also, look here for the API Documentation on add titleblock....
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-F9EB14F1-F2D8-41CC-8B61-07B9A5478267
ex://
Set oTitleBlock = oSheet.AddTitleBlock("ANSI A",, sPromptStrings)
Hi Shawn,
Yes, it is very simple.
Make sure that before adding title block, existing title block should be deleted.
Dim oSourceDocument As DrawingDocument Set oSourceDocument = ThisApplication.ActiveDocument ' Open the template drawing to copy the title block from. Dim oNewDocument As DrawingDocument ' if you put false here at the end it will not open visible, so you won't need to close it Set oNewDocument = ThisApplication.Documents.Open("Q:\Inventor\Templates_v2014\Templates\part.idw", False) ' Get the new title block definition. Dim oNewTitleBlockDef As TitleBlockDefinition 'make sure that in your template.idw the needed titleblock is active Set oNewTitleBlockDef = oNewDocument.ActiveSheet.TitleBlock.Definition ' Set the new title block definition. Dim oSourceTitleBlockDef As TitleBlockDefinition Set oSourceTitleBlockDef = oNewTitleBlockDef.CopyTo(oSourceDocument) ' Iterate through the sheets. Dim oSheet As Sheet For Each oSheet In oSourceDocument.Sheets oSheet.Activate
Call oSheet.TitleBlock.Delete
Dim oTitleBlock As TitleBlock Set oTitleBlock = oSheet.AddTitleBlock("ANSI A") Next End Sub
One more point, title block "ANSI A" should be available in Drawing resources of activedocument.
Please feel free to contact if there is any doubt.
If solve your problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
Hi
i have copied your code and pasted in VBA editor... the code works fine upto deleting Title block and showing an error exactly at below mentioned line...
Please help...
Thanks in Advance.
Well, As mentioned above, my problem was that I had prompted entries. I assume that is your problem as well. So I wanted to capture the information that was already in the prompted entries and retain that information so that once I brought in the updated title block that I would not lose that information. I also wanted to make sure that I went through all pages and updated the title block on each and every page. Here is the code I came up with but you will have to modify it to match your prompted entry titles.
Sub Update_TitleBlock(OrigFileLoc, oDocIDW, DerivedPartOriginalFile, SavedName)
Dim oDocIDWStyles As Inventor.DrawingStylesManager
Set oDocIDWStyles = oDocIDW.StylesManager
Dim i As Integer
On Error Resume Next
'Update Sytles to Global
For i = 1 To oDocIDWStyles.Styles.Count
' Debug.Print "Styles - " + oDocIDWStyles.Styles.Item(i).Name
If oDocIDWStyles.Styles.Item(i).UpToDate = False Then
'MsgBox oDocIDWStyles.Styles.Item(i).Name
If oDocIDWStyles.Styles.Item(i).Name = "ANSI" Then
oDocIDWStyles.Styles.Item(i).UpdateFromGlobal
End If
If oDocIDWStyles.Styles.Item(i).Name = "Bradbury-H" Then
End If
End If
Next
If (oDocIDW.DocumentType <> kDrawingDocumentObject) Then Exit Sub
Dim oTemplate As DrawingDocument
Dim oSheet As Sheet
Dim titlename As String
Dim oPane As BrowserPane
Dim oDocumentNode As BrowserNode
Dim oDrawingResourceNode As BrowserNode
Set oSheet = oDocIDW.ActiveSheet
Set oTitleBlock = oSheet.TitleBlock
If oTitleBlock.Definition.Sketch.TextBoxes Is Nothing Then Exit Sub
Set oTextBoxes = oTitleBlock.Definition.Sketch.TextBoxes
For Each oTextBox In oTextBoxes
'MsgBox oTextBox.Text
If oTextBox.Text = "MJS" Then
'MsgBox ("This is a Part")
fname = "Bradbury Template.idw"
GoTo DoneWithThisFor
ElseIf oTextBox.Text = "Enter Raw Stock Noun" Then
fname = "PART.idw"
'MsgBox SecondDescr
ElseIf oTextBox.Text = "CROSS-SECTION" Then
'MsgBox ("This is a Cross Section")
fname = "Cross Section.idw"
ElseIf oTextBox.Text = "MACHINE TYPE" Then
'MsgBox ("This is a LUBE TEMPLATE")
fname = "LUBETEMPLATE.idw"
ElseIf oTextBox.Text = "MISCELLANEOUS MATERIALS" Then
'MsgBox ("This is a MISC_INSTALL")
fname = "MISC_INSTALL.idw"
ElseIf oTextBox.Text = "INSTALLATION DRAWING" Then
'MsgBox ("This is a INSTALLATION DRAWING")
fname = "RT Installation.idw"
Else
fname = "ASSY.idw"
End If
Next
'End of Extraction
DoneWithThisFor:
Dim a As Integer
Dim b As Integer
Dim c As Integer
Dim d As Integer
Dim e As Integer
Dim f As Integer
Dim Count As Integer
Dim TitleBlockArray() As Variant
Dim oBorderDefinition As BorderDefinition
Dim oTitleBlockDefinition As TitleBlockDefinition
If fname = "Cross Section.idw" Then
Set oTemplate = ThisApplication.Documents.Open(ThisApplication.FileOptions.TemplatesPath & fname, False)
Set oSourceTitleBlockDef = oTemplate.ActiveSheet.TitleBlock.Definition
Set oNewTitleBlockDef = oSourceTitleBlockDef.CopyTo(oDocIDW, True)
oTemplate.Close
Count = oDocIDW.Sheets.Count * 3
a = 0
b = 1
c = 2
d = 3
e = 4
f = 5
ReDim TitleBlockArray(Count) As Variant
For Each oSheet In oDocIDW.Sheets
If oSheet.TitleBlock Is Nothing Then Exit Sub
If oTextBox.Text = "Enter Second Line Description" Then
SecondDescr = oTitleBlock.GetResultText(oTextBox)
ElseIf oTextBox.Text = "PART No." Then
PartNo = oTitleBlock.GetResultText(oTextBox)
ElseIf oTextBox.Text = "SCALE" Then
SCALEtxt = oTitleBlock.GetResultText(oTextBox)
End If
Next
Array4text:
TitleBlockArray(a) = SecondDescr
TitleBlockArray(b) = PartNo
TitleBlockArray(c) = SCALEtxt
a = a + 3
b = b + 3
c = c + 3
Count = Count - 1
Next
'Delete the Titleblock from all sheets
For oSheetNumber = 1 To oDocIDW.Sheets.Count
Set oSheet = oDocIDW.Sheets(oSheetNumber)
Next
For Each oTitleBlockDefinition In oDocIDW.TitleBlockDefinitions
If oTitleBlockDefinition.Name = "ANSI A" Then
oTitleBlockDefinition.Delete
End If
Next
Set oNewDocument = ThisApplication.Documents.Open(ThisApplication.FileOptions.TemplatesPath & fname, False)
Set oSourceTitleBlockDef = oNewTitleBlockDef.CopyTo(oDocIDW)
oNewDocument.Close
Count = Count - 1
Dim FinalCount As Integer
FinalCount = Count
Count = 0
oSheet.Activate
a = Count
b = Count + 1
c = Count + 2
SavedName = Right(SavedName, Len(SavedName) - 3)
SavedName = "BCO-" & SavedName
Dim sPromptString(0 To 6) As String
sPromptString(0) = SavedName
sPromptString(1) = TitleBlockArray(a)
sPromptString(2) = ""
sPromptString(3) = TitleBlockArray(c)
sPromptString(4) = ""
sPromptString(5) = ""
sPromptString(6) = ""
sPromptString(7) = ""
'Puts Titleblock back in to sheet
Set oTitleBlock = oSheet.AddTitleBlock("ANSI A", , sPromptString)
Count = Count + 3
Next
Else
oTemplate.Close
' Dim a As Integer
' Dim b As Integer
' Dim c As Integer
' Dim Count As Integer
a = 0
b = 1
c = 2
' Dim TitleBlockArray() As Variant
Noun = oTitleBlock.GetResultText(oTextBox)
ElseIf oTextBox.Text = "Enter Raw Stock Description" Then
RawStock1Desc = oTitleBlock.GetResultText(oTextBox)
End If
Next
'Array4text:
TitleBlockArray(b) = Noun
TitleBlockArray(c) = RawStock1Desc
a = a + 3
b = b + 3
c = c + 3
Count = Count - 1
Next
Next
' Dim oBorderDefinition As BorderDefinition
' Dim oTitleBlockDefinition As TitleBlockDefinition
End If
Next
' Dim oNewDocument As DrawingDocument
oNewDocument.Close
Count = Count - 1
' Dim FinalCount As Integer
FinalCount = Count
Count = 0
oSheet.Activate
a = Count
b = Count + 1
c = Count + 2
Dim sPromptStrings(0 To 3) As String
sPromptStrings(0) = TitleBlockArray(a)
sPromptStrings(1) = TitleBlockArray(b)
sPromptStrings(2) = TitleBlockArray(c)
sPromptStrings(3) = ""
Set oTitleBlock = oSheet.AddTitleBlock("ANSI A", , sPromptStrings)
Count = Count + 3
Next
End If
Exit Sub
End Sub
