Thumbnail form custom Content Center library. Can you get the normalt thumbnail ?
I would like to see the current file and not an standard thumbnail form content center
like this
not like this
is this possible ?
Solved by Michael.Navara. Go to Solution.
Is this what you need?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
No. I need to be ably to see the finished part. We are using Content center to create custom part with a lot of properties on. so we start out selecter a round bars Ø35 x lenght by using the Counter Center as custom
then we might add some more feature after that.. Today All Round bart thoumbnail looks like this
no matter what we have done with it.. I want to see the real part that might look like this
or
or
This is a document setting. Change it in iProperties window -> Save
Looks like that work. is that a change i need to make on the templete file or a setting in inventor .. If I want all files like that ?
thanks for the help so fare 😀
In my opinion it is not possible to change this setting in template, because each family in ContentCentrer has it's own template
But you can switch it by simple iLogic script (before save, after new, etc.).
Dim doc As Document = ThisDoc.Document
doc.SetThumbnailSaveOption(ThumbnailSaveOptionEnum.kActiveComponentIsoViewOnSave)
If it's useful to anyone, I run this from Part or Assembly level to modify ALL parts to ISO view of Thumbnail. Enjoy.
Public Sub Main()
If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Try
'set iproperty to use ISO view on save
oDoc.SetThumbnailSaveOption _
'save the file
oDoc.Save
Catch
End Try
ElseIf ThisApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oFileInfo As String = oDoc.FullFileName
Dim result = MessageBox.Show("You're running multiple parts in this Assembly " & vbCr & fileName & vbCr & "Do you want to continue??", "Run GS and Other Rules", MessageBoxButtons.OKCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
If result = vbOK Then
RunExternalRules
Else
Return
End If
Dim oProgressBar As Inventor.ProgressBar
oProgressBar = ThisApplication.CreateProgressBar(False, PartCount, oMessage, True)
End If
End Sub
Sub RunExternalRules
oDoc = ThisApplication.ActiveDocument
Dim iDoc As Document
'Set counter for counting parts
Dim iPartCount As Integer
iPartCount = 0
'Progress bar
oMessage = "Editing All Parts And Saving, Please Wait..."
PartCount = oDoc.AllReferencedDocuments.Count
Dim assembly As Inventor.AssemblyDocument = ThisDoc.Document
'Iterate through all of the occurrences in the assembly
For Each iDoc In oDoc.AllReferencedDocuments
iPartCount = iPartCount + 1
Dim fileName As String = IO.Path.GetFileNameWithoutExtension(iDoc.FullFileName)
'Update the progress bar
'If UserWantsToCancel Then Return
oProgressBar.Message = ("Working on part " & iPartCount & " of " & PartCount & " | " & fileName)
oProgressBar.UpdateProgress
Try
ThisApplication.Documents.Open(iDoc.FullFileName)
IDoc.SetThumbnailSaveOption _
'save the file
iDoc.Save
iDoc.Close
Catch
iDoc.Close
End Try
Next
oProgressBar.Close
End Sub
Private Function UserWantsToCancel(oprogressBar As Inventor.ProgressBar)
If (UserClickedOnCancel) Then
MsgBox("User clicked cancel and it has been detected now.")
' Add code here for clean exit of the rule.
' If you work with transactions then this could be
' the place To role back any changes
oprogressBar.Close()
Return True
End If
Return False
End Function
