Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Textbox will not accept return
17 REPLIES 17
Message 1 of 18
MattH_Work
766 Views, 17 Replies
I'm building forms that are hosted inside a dockable window. Multiline textboxes will not allow a 'return'
An older addin will work but for my sins I cannot find the difference in the code that turn on/off the 'return' key
The textboxes are set to 'multiline = true', & 'wordwrap=true' & 'acceptsreturn = true' and I have tried multiple combinations
Can anyone point me in the right direction
MattH
Product Design Collection 2025
Vault Pro 2025
17 REPLIES 17
Message 2 of 18
can you show a screenshot of the properties?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 3 of 18
If multiline is set to false, the textbox height becomes fixed and therefore I can only see one line
Also, it still does not accept the enter key to create a new line
MattH
Vault Pro 2025
Message 4 of 18
can you give the code or the properties of the textbox
Arthur Knoors
Message 5 of 18
As requested
MattH
Vault Pro 2025
Message 6 of 18
Currently, there is no code relating to the textbox directly.
Once the textbox is populated, the TxtBx.text is used downstream
MattH
Vault Pro 2025
Message 7 of 18
and you mean this return
Arthur Knoors
Message 8 of 18
Exactly.
If I create a dummy form in a standalone exe (not Inventor dll) I can get the result I want (as shown in your screenshot)
If the form is part of an Inventor addin, in this case 'hosted' within a dockable form then the return key is ignored. Text can only be on one line
I think I read on this discussion group somewhere about others having simialr issues, but have been unable to find it
MattH
Vault Pro 2025
Message 9 of 18
Is the form shown as modal or modeless?
frm.show
or
frm.showdialog
Arthur Knoors
Message 10 of 18
MattH_Work
in reply to: MattH_Work
Now its getting silly
Was about to take a screenshot of an addin that works (refered to in my original post) but it also now refuses to accept the enter key
NOTHING has changed in the code
MattH
Vault Pro 2025
Message 11 of 18
frm.show
or
frm.showdialog
Private Sub InventorAddInButtonDef_OnExecute(ByVal Context As Inventor.NameValueMap) Handles InventorAddInButtonDef.OnExecute
     If oApp.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
          CreateDockableWindow()
End Sub
Private Sub CreateDockableWindow()
     Dim oUserInterfaceMgr As UserInterfaceManager
     oUserInterfaceMgr = m_inventorApplication.UserInterfaceManager
     oWindow_Dock = Nothing
Try
     oWindow_Dock = oUserInterfaceMgr.DockableWindows.Add(m_ClientId, "XXX", DockableWindow_Title)
     Catch
     oWindow_Dock = oUserInterfaceMgr.DockableWindows.Item("XXXr")
End Try
     oWindow_Dock.DisabledDockingStates = DockingStateEnum.kDockTop + DockingStateEnum.kDockBottom
     oWindow_Dock.DockingState = DockingStateEnum.kDockLeft
     oWindow_Dock.SetMinimumSize(oWindow_Dock_Height, oWindow_Dock_Width)
     oWindow_Dock.Visible = True
End Sub
Private Sub DocWinEvents_OnShow(DockableWindow As DockableWindow, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum)
     If DockableWindow.Title = DockableWindow_Title Then
          Dim FormVis As String = Nothing
          FormVis = oForm_Dock.Visible.ToString
          If FormVis = False Then
               Dim oForm_Dock As New Frm_InventorAddIn
               oWindow_Dock.AddChild(oForm_Dock.Handle)
               oForm_Dock.Show()
End Sub
MattH
Vault Pro 2025
Message 12 of 18
rogmitch
Does it by any chance work with SHIFT-RETURN  ?
Roger Mitchell
Message 13 of 18
MattH_Work
in reply to: rogmitch
Nope...
MattH
Vault Pro 2025
Message 14 of 18
               oForm_Dock.Showdialog
Arthur Knoors
Message 15 of 18
nmunro
When Autodesk updated dockable windows (2018 I think) they broke keyboard handling in these forms such that some key events get handled by Inventor rather than the form or the controls within it. For a modeless form in a dockable window the ability to assign the Inventor window as the owner of the modeless form was removed. It just ignores the "Owner" argument.
You can get around some of this by responding to KeyDown events in your controls/form but to completely fix it you may need to write low-level keyboard handling routines (ugh).
https://c3mcad.com
Message 16 of 18
MattH_Work
in reply to: nmunro
Using the following code gives no response, zero results
Private Sub TxtBx_ID_Text_KeyDown(sender As Object, e As KeyEventArgs) Handles TxtBx_ID_Text.KeyDown
If e.KeyCode = Keys.Enter Then
TxtBx_ID_Text.Text &= vbCr
End Sub
Any other key press is detected, but the enter key is completely ignored!
MattH
Vault Pro 2025
Message 17 of 18
If I use .showdialog, I cannot interact with the form at all
MattH
Vault Pro 2025
Message 18 of 18
MattH_Work
in reply to: nmunro
Sorted
Private Sub TxtBx_ID_Text_KeyUp(sender As Object, e As KeyEventArgs) Handles TxtBx_ID_Text.KeyUp
If e.KeyValue = 13 Then
TxtBx_ID_Text.Text &= vbCrLf
TxtBx_ID_Text.SelectionStart = Len(TxtBx_ID_Text.Text)
TxtBx_ID_Text.ScrollToCaret()
End Sub
MattH
Vault Pro 2025
