TABLE COLUM HEADER JUSTIFICATION
2 REPLIES 2
373 Views, 2 Replies
Hi, im trying to bottom justify the text in the column header but i just can´t, i already made the proper layout in the Style Editor
2 REPLIES 2
bradeneuropeArthur
Think this is not supported via the API!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
I have tested:
And this seems to be not supported.
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Sheet
Set c = b.Sheets.Item(1)
Dim pl As PartsList
Set pl = c.PartsLists.Item(1)
Dim plc As PartsListColumn
Set plc = pl.PartsListColumns.Item(1)
plc.TitleHorizontalJustification = kAlignTextLeft
'plc.TitleVerticaljustification ....... This is not supported
End Sub
Arthur Knoors
Technology Administrators
