Set PosRep in Subassembly
4 REPLIES 4
jR0sal3s
484 Views, 4 Replies
i am just copying macros whichever fit my needs....and i came across a vba view rep code...can this be converted to a positional representation?
the structure would be the same, top level assembly and sub assembly 1, 2, 3, etc...i need to set the posrep of the sub assemblies..
any help is much appreciated...
thanks joel..
the following code is the closest i could reference however it is based on view rep...
Dim aDoc As AssemblyDocument
Set aDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As ComponentDefinition
Dim oCompOcc As Inventor.ComponentOccurrence
Set oAsmCompDef = aDoc.ComponentDefinition
For Each oCompOcc In oAsmCompDef.Occurrences
If oCompOcc.Visible = True Then
If oCompOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
Call oCompOcc.SetDesignViewRepresentation("DH - MB", , True)
Else
End If
Else
End If
On Error Resume Next
Next
4 REPLIES 4
Put the following in your code between the for each loop:
try
Dim a As Inventor.PositionalRepresentation a.SetPositionalRepresentationOverride(ocompocc,"name of Pos"
Catch ex As Exception
end try
then you need to know the name of the PosRepresentation to be set as "Name of Pos"
Arthur Knoors
Autodesk Affiliations:
it doesn't accept the code...its red
"set a.SetPositionalRepresentationOverride(oCompOcc, "Free Drag - SW")"
this one seems to work but on the top level assembly only....how can this be modified to go sub assembly 1, 2, 3,..etc...
' get the current assembly
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
' get AssemblyComponentDefinition
Dim AssemblyDef As AssemblyComponentDefinition
Set AssemblyDef = oDoc.ComponentDefinition
' get the component occurence
' get Manager of Representations
Dim dViewRepMgr As RepresentationsManager
Set dViewRepMgr = AssemblyDef.RepresentationsManager
' get pos rep settings
Set dViewRep = dViewRepMgr.PositionalRepresentations.Item(3)
' activate the first view
dViewRep.Activate
Please show me what you have written between the for each loop excactly
Arthur Knoors
here..as what i understand..
"a.SetPositionalRepresentationOverride(ocompocc,"Free Drag - SW")
end try"
the above lines appears in red.....seems not accepted by VBA..?
Public Sub testposrepsubassy()
'Call oCompOcc.SetDesignViewRepresentation("Free Drag - SW", , True)
try
end try
Else
End If
Else
End If
Next
End Sub
