Hi there folks,
Slowly gaining my iLogic knowledge but curious to know if there was a means (via iLogic) to select two parallel faces within an assembly that then was applied to a user parameter? Basically the same as the measure tool but the result is a forced to update the numerical parameter.
Make a sketch and project these workplanes as reference lines, place a sketch dimension and you have your parameter as needed.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
