hello this is a rule that exports the list of materials to excel with a template and with thumbnails, generates the thumbnails of each reference file and then adds them as a comment, to achieve increasing the size of the view to taste without increasing the size from the list of materials. Care should be taken as to how values and file paths are entered.
If the Inv language is in English it should correct "structured" and "parts only"
I hope you understand greetings
Sub Main()
On Error Resume Next
Dim Dirtemp As String = "C:\Users\Sergio\AppData\Local\Temp\" '''Especifique la ruta de la carpeta temporal
Dim Dirxlsx As String = "E:\Libro1.xlsx" ''' Especifique la ruta de la plantilla
Dim osheetbom As String = "BOM" ''' Especifique la hoja de la plantilla
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
' Set the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
' Make sure that the parts only view is enabled.
oBOM.PartsOnlyViewEnabled = True
' Establece el tipo de lista de materiales, estructurado o solo partes
Dim oValueList As New ArrayList
oValueList.Add("Estructurado") ''' Si el idioma de Inv esta en ingles corregir a "Structured"
oValueList.Add("Solo Piezas") ''' Si el idioma de Inv esta en ingles corregir a "Parts Only"
Dim oValue As String
oValue = InputListBox("Selecciona el tipo de Lista a exportar", oValueList, "Estructurado", "iLogic", "Selecciones Disponibles")
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item(oValue)
Dim orden As String = InputBox("Ordenar por", "Exportar BOM", "Part Number")
oBOMView.Sort(orden, True)' Indicar por medio de que factor se ordenara la lista
oBOMView.Renumber(1, 1)
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Open(Dirxlsx)
xlWorksheet = xlWorkbook.Worksheets.Item(osheetbom)
Dim row As Integer
row = 3 ''' Indicar a partir de que fila comenzara el copiado a excel
'Dim bRow As bomRow
bRows = oBOMView.BOMRows
For Each bRow In bRows
Dim rDoc As Inventor.Document'Document
rDoc = bRow.ComponentDefinitions.Item(1).Document
Dim rDocName As String = rDoc.DisplayName
Dim m_Camera As Inventor.Camera
m_Camera = ThisServer.TransientObjects.CreateCamera()
If rDoc.DocumentType = kPartDocumentObject Then
m_Camera.SceneObject = DirectCast(rDoc, PartDocument).ComponentDefinition
Else
m_Camera.SceneObject = DirectCast(rDoc, AssemblyDocument).ComponentDefinition
m_Camera.Perspective = True
Dim m_TO As Inventor.TransientObjects
m_TO = ThisApplication.TransientObjects
m_Camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
m_Camera.Fit
m_Camera.ApplyWithoutTransition
ThisApplication.DisplayOptions.NewWindowDisplayMode = DisplayModeEnum.kShadedWithEdgesRendering
ThisApplication.DisplayOptions.Show3DIndicator = False
Dim TumbFilename As String = Dirtemp & rDocName & ".bmp"
m_Camera.SaveAsBitmap(TumbFilename, 800, 600, m_TO.CreateColor(255,255,255))
'Next
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
'Se seleccionan las columnas de tabla que se exportaran al archivo excel asi como su ubicacion
xlWorksheet.Range("A" & row).Value = bRow.ItemQuantity
xlWorksheet.Range("B" & row).Value = docPropertySet.Item("Part Number").Value
xlWorksheet.Range("C" & row).Value = docPropertySet.Item("Description").Value
With xlWorksheet.Range("B" & row)
.AddComment
.Comment.Visible = False
.Comment.Text(rDocName)
.Comment.Shape.Fill.UserPicture(TumbFilename)
.Comment.Shape.Height = 150
.Comment.Shape.Width = 150
End With
'xlWorksheet.Range("A" & row).Value = bRow.ItemNumber
'xlWorksheet.Range("E" & row).Value = docPropertySet.Item("Cost").Value
'xlWorksheet.Range("F" & row).Value = docPropertySet.Item("Stock number").Value
'xlWorksheet.Range("G" & row).Value = docPropertySet.Item("Vendor").Value
row = row + 1
Next
xlWorksheet.Columns("A:Z").AutoFit
Dim oFileName As String = "Export_" & oDoc.DisplayName & ".xlsx"
MessageBox.Show(oFileName , "Exportando a")
xlWorkBook.SaveAs(ThisDoc.Path & "\" & oFileName)' El archivo de excel se guardara en la ubicacion del archivo de ensamblaje
xlWorkbook.Close (True)
xlApp.Quit
End Sub
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
