Save Thumbnail vba macro to iLogic
I'm trying to adapt the code below to an iLogic rule taken from VBA macro
Sub Main SaveThumbnail()
    ' Get the active document.
    Dim doc As Document
    doc = ThisApplication.ActiveDocument
    ' Get the thumbnail from the document.
    Dim thumb As IPictureDisp
    thumb = doc.Thumbnail
    ' Create the filename for the bmp file so it is the same
    ' as the document name but with a "bmp" extension.
    Dim filename As String
    filename = Left$(doc.FullFileName, Len(doc.FullFileName) - 3) & "bmp"
    ' Save the thumbnail.
    Call SavePicture(thumb, filename)
End Sub
 I get errors saying:
Error on Line 8 : Reference required to assembly 'stdole, Version=7.0.3300.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' containing the type 'stdole.IPictureDisp'. Add one to your project.
Error on Line 16 : 'SavePicture' is not declared. It may be inaccessible due to its protection level.
Can anyone advise how to fix please?
MechMachineMan
Above it....
AddReference "stdole.dll"
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
hey @MechMachineMan
thanks, that took care of the first error. I'm still getting 'SavePicture is not declared'
Do I need to proceed it with something?
Sergio.D.Suárez
hello this is a rule that exports the list of materials to excel with a template and with thumbnails, generates the thumbnails of each reference file and then adds them as a comment, to achieve increasing the size of the view to taste without increasing the size from the list of materials. Care should be taken as to how values and file paths are entered.
If the Inv language is in English it should correct "structured" and "parts only"
I hope you understand greetings
Sub Main()
On Error Resume Next
Dim Dirtemp As String = "C:\Users\Sergio\AppData\Local\Temp\"     '''Especifique la ruta de la carpeta temporal
Dim Dirxlsx As String = "E:\Libro1.xlsx"                          ''' Especifique la ruta de la plantilla
Dim osheetbom As String = "BOM"                                   ''' Especifique la hoja de la plantilla
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
    ' Set the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
    ' Make sure that the parts only view is enabled.
oBOM.PartsOnlyViewEnabled = True
    ' Establece el tipo de lista de materiales, estructurado o solo partes
Dim oValueList As New ArrayList
oValueList.Add("Estructurado") ''' Si el idioma de Inv esta en ingles corregir a "Structured"
oValueList.Add("Solo Piezas") ''' Si el idioma de Inv esta en ingles corregir a "Parts Only"
Dim oValue As String
	oValue = InputListBox("Selecciona el tipo de Lista a exportar", oValueList, "Estructurado", "iLogic", "Selecciones Disponibles")
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item(oValue)
Dim orden As String = InputBox("Ordenar por", "Exportar BOM", "Part Number")
oBOMView.Sort(orden, True)' Indicar por medio de que factor se ordenara la lista
oBOMView.Renumber(1, 1)
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Open(Dirxlsx)
xlWorksheet = xlWorkbook.Worksheets.Item(osheetbom)
Dim row As Integer
row = 3                 ''' Indicar a partir de que fila comenzara el copiado a excel
'Dim bRow As bomRow
bRows = oBOMView.BOMRows
For Each bRow In bRows
Dim rDoc As Inventor.Document'Document
rDoc = bRow.ComponentDefinitions.Item(1).Document
Dim rDocName As String = rDoc.DisplayName
Dim m_Camera As Inventor.Camera
m_Camera = ThisServer.TransientObjects.CreateCamera()
If rDoc.DocumentType = kPartDocumentObject Then
  m_Camera.SceneObject = DirectCast(rDoc, PartDocument).ComponentDefinition
Else
  m_Camera.SceneObject = DirectCast(rDoc, AssemblyDocument).ComponentDefinition
End If
m_Camera.Perspective = True
Dim m_TO As Inventor.TransientObjects
m_TO = ThisApplication.TransientObjects
m_Camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
m_Camera.Fit
m_Camera.ApplyWithoutTransition
ThisApplication.DisplayOptions.NewWindowDisplayMode = DisplayModeEnum.kShadedWithEdgesRendering
ThisApplication.DisplayOptions.Show3DIndicator = False
Dim TumbFilename As String = Dirtemp & rDocName & ".bmp"
m_Camera.SaveAsBitmap(TumbFilename, 800, 600, m_TO.CreateColor(255,255,255))
'Next
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
'Se seleccionan las columnas de tabla que se exportaran al archivo excel asi como su ubicacion
xlWorksheet.Range("A" & row).Value = bRow.ItemQuantity
xlWorksheet.Range("B" & row).Value = docPropertySet.Item("Part Number").Value
xlWorksheet.Range("C" & row).Value = docPropertySet.Item("Description").Value
With xlWorksheet.Range("B" & row)
            .AddComment
            .Comment.Visible = False
			.Comment.Text(rDocName)
            .Comment.Shape.Fill.UserPicture(TumbFilename)
            .Comment.Shape.Height = 150
            .Comment.Shape.Width = 150
End With
'xlWorksheet.Range("A" & row).Value = bRow.ItemNumber
'xlWorksheet.Range("E" & row).Value = docPropertySet.Item("Cost").Value
'xlWorksheet.Range("F" & row).Value = docPropertySet.Item("Stock number").Value
'xlWorksheet.Range("G" & row).Value = docPropertySet.Item("Vendor").Value
row = row + 1
Next
xlWorksheet.Columns("A:Z").AutoFit
Dim oFileName As String = "Export_" &   oDoc.DisplayName & ".xlsx"
MessageBox.Show(oFileName , "Exportando a")
xlWorkBook.SaveAs(ThisDoc.Path & "\" & oFileName)' El archivo de excel se guardara en la ubicacion del archivo de ensamblaje
xlWorkbook.Close (True)
xlApp.Quit
 End Sub
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Reitshammer
Hello, I tested your code in IV2024. Unfortunately, it doesn't work for me, and I can't see any errors. Can you help me further? Thank you in advance.
Sub Main()
    Dim Dirtemp As String = "C:\temp\"     '''Geben Sie den Pfad zum temporären Ordner an
    Dim Dirxlsx As String = "C:\Vault\Vorlage.xlsx"                          '''Geben Sie den Pfad zur Vorlage an
    Dim osheetbom As String = "Gesamt"                                   '''Geben Sie das Blatt der Vorlage an
    Dim oBOM As BOM
    ' Setzen Sie die strukturierte Ansicht auf "alle Ebenen"
    ' Stellen Sie sicher, dass die strukturierte Ansicht aktiviert ist.
    ' Stellen Sie sicher, dass die Ansicht "Nur Teile" aktiviert ist.
    ' Legen Sie den Typ der Stückliste fest, strukturiert oder nur Teile
    oValueList.Add("Structured") ''' Wenn die Sprache von Inventor auf Englisch eingestellt ist, ändern Sie dies in "Structured"
    oValueList.Add("Parts Only") ''' Wenn die Sprache von Inventor auf Englisch eingestellt ist, ändern Sie dies in "Parts Only"
    oValue = InputListBox("Wählen Sie den zu exportierenden Listentyp", oValueList, "Estructurado", "iLogic", "Verfügbare Auswahlmöglichkeiten")
    Dim orden As String = InputBox("Sortieren nach", "Stückliste exportieren", "Part Number")
    oBOMView.Sort (orden, True) ' Geben Sie an, nach welchem Faktor die Liste sortiert wird
    oBOMView.Renumber (1, 1)
    Dim xlApp As Object
    Dim xlWorkbook As Object
    Dim xlWorksheet As Object
    Dim row As Integer
    row = 7                 ''' Geben Sie an, ab welcher Zeile das Kopieren nach Excel beginnt
    Dim bRow As BOMRow
	bRow = oBOMView.BOMRows
        Dim rDoc As Inventor.Document 'Dokument
        rDocName = rDoc.DisplayName
        Else
        End If
        m_Camera.Fit
        TumbFilename = Dirtemp & rDocName & ".bmp"
        m_Camera.SaveAsBitmap (TumbFilename, 800, 600, m_TO.CreateColor(255, 255, 255))
        'Next
        'Wählen Sie die Tabellenspalten aus, die in die Excel-Datei exportiert werden sollen, sowie deren Position
            .AddComment
            .Comment.Text (rDocName)
            .Comment.Shape.Fill.UserPicture (TumbFilename)
        End With
        xlWorksheet.Range("D" & row).Value = bRow.ItemNumber
        row = row + 1
    Next
    'xlWorksheet.Columns("A:Z").AutoFit
    oFileName = "Export_" & oDoc.DisplayName & ".xlsx"
    MessageBox.Show (oFileName, "Exportieren nach")
    xlWorkbook.SaveAs (ThisDoc.Path & "\" & oFileName) ' Die Excel-Datei wird im Verzeichnis der Baugruppendatei gespeichert
    xlApp.Quit
End Sub
