Hi all,
I need to run more apprentice server component from a my application.
To do this I use more tasks but the problem is that the apprentices don't works, only 1 at time is working.
I need to do this because I have to manage a lot of files (about 300000) and is better have more tasks to check all.
If I create more than 1 application they works, I can understand that I can manage 1 apprentice server of each my application.
Someone knows this argument?
Thanks a lot
Solved by BrianEkins. Go to Solution.
Does this work:
Dim a1 As Inventor.ApprenticeServer = New Inventor.ApprenticeServerComponent
Dim b1 As Inventor.ApprenticeServerDrawingDocument = Nothing
'Dim c1 As Inventor.ApprenticeServerDocument = Nothing
Dim a2 As Inventor.ApprenticeServer = New Inventor.ApprenticeServerComponent
Dim b2 As Inventor.ApprenticeServerDrawingDocument = Nothing
'Dim c2 As Inventor.ApprenticeServerDocument = Nothing
b1 = a1.Open(FullName)
b2 = a2.Open(FullName)
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Ok, but I want that all works in the same time and this not happen in this way. I tried.
I tried to insert the code in a separate thread but they don't work in the same time, for example
Apprentice 1 is opening a big assembly (20 seconds)
I want open an ipt with Apprentice 2 and it will open the file only after Apprentice 1 has finished its operation.
Now I created an external .exe (command line) and I start more istances of .exe and in this way all work fine
use: Application.DoEvents()
Arthur Knoors
Hey
maybe this link could help?
https://adndevblog.typepad.com/manufacturing/2014/09/apprentice-in-side-thread.html
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Apprentice is loaded and runs within the process of the program that is using it. Apprentice doesn't support multi-threading so you can't have a unique Apprentice associated with separate threads in the process. To work around this you'll need to have multiple processes (exe's) where each one starts and drives Apprentice.
