hobe you can help
I made a content to a content center Excel ark.. With for some reason cause it to complete deletet all content is it. is there a way to restore it ? , Can I find a old version on the server somehow ?
are you using Desktop Content Center or Vault Content Center?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Vault Content Center I think. We are our custom made content Center family .. I did a change it one of them and for some reason it delete all the table in this family. I was only trying to a one at the top
You cannot restore a deleted table!
Arthur Knoors
then I have to invent one. I have restore it now. But was lucky it was small one . one of the other I have has more the a 1000´s lines
Did you re-create the table new.
Than you need to be careful with this method when refreshing or replacing Content Center Parts, because the have a different internal ID now!
Arthur Knoors
I do not think that will be the problem ... I have not test it ... but I didn´t lose the family ... only the Parameter in the Table..but it I did it have only been use in a few part so far ... so the lost will not be that big...but I have some large and old ones... that have been use to create a lot of part ..and I will be in problem
