Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Quickly assign materials to multiple parts in an assembly
4 REPLIES 4
kenneth_paulsen
399 Views, 4 Replies
I am trying to assign water as a material for all parts in an assembly and subassembly. I want to do this rapidly and then back to the previous materials (several different materials) .
Labels (4)
4 REPLIES 4
Via the Bill Of Material?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Hi @kenneth_paulsen.  What would be the purpose of rapidly changing the material of all parts in an assembly to a specific material, then changing them all back?  Do you truly need to change their material, or would just changing their appearance be OK.  Changing their material will make a change to the individual files that the components are referencing, not just the component objects in the assembly.  Plus, that material needs to be 'locally' available within each part, not just a material that is available in the material library.  There needs to be a local copy of the material stored in the part, before the part can be set to that material, at least that is how it works by code.  When doing things manually, stuff automatically happens behind the scenes that we do not realize, to help things go smoothly.
Here is an example iLogic rule for recursively iterating through all components in an assembly, and changing the material of all of its parts to 'Water'.  It uses a 'Transaction', so that you can potentially undo the changes when it is done.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
		Exit Sub
	End If
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	Dim oOccs As ComponentOccurrences = oADef.Occurrences
	Dim oInvMatLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Inventor Material Library")
	oLibraryWaterMaterial = oInvMatLib.MaterialAssets.Item("Water")
	Dim oTrans As Inventor.Transaction = ThisApplication.TransactionManager.StartTransaction(oADoc, "Change Materials - iLogic")
	RecurseComponents(oOccs)
	oTrans.End
	If oADoc.RequiresUpdate Then oADoc.Update2(True)
	'If oADoc.Dirty Then oADoc.Save2(True)
End Sub
Dim oLibraryWaterMaterial As MaterialAsset
Sub RecurseComponents(oOccs As ComponentOccurrences)
	If oOccs Is Nothing OrElse oOccs.Count = 0 Then Return
	For Each oOcc As ComponentOccurrence In oOccs
		If oOcc.Suppressed Then Continue For
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
			Dim oOccPDoc As PartDocument = oOcc.Definition.Document
			Dim oLocalWaterMaterial As MaterialAsset = Nothing
			Try
				oLocalWaterMaterial = oOccPDoc.MaterialAssets.Item("Water")
			Catch
				oLocalWaterMaterial = oLibraryWaterMaterial.CopyTo(oOccPDoc, True)
			End Try
			Try
				oOccPDoc.ActiveMaterial = oLocalWaterMaterial
			Catch
				'what to do if that fails
			End Try
		End If
		If oOcc.Suppressed = False AndAlso _
			oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			RecurseComponents(oOcc.Definition.Occurrences)
			'RecurseComponents(oOcc.SubOccurrences)
		End If
	Next
End Sub
We could have optionally used the iLogic method iProperties.Material(oOcc.Name) = "Water" on those components too, but I am showing the Inventor API way of doing it, instead of the iLogic way.
Wesley Crihfield
(Not an Autodesk Employee)
Hi Arthur,
Yes, that was seemingly a better way of doing it than I did previously (opening each part and manually changing it).
The purpose of changing to water and then back again to the previous material is to calculate/find the center of buoyancy in an assembly.
