Evening all
I have a rule that positions each view label at a set distance below each view. Is there a way to move the label based on the number of dimensions below the view. I found this rule a while ago (And cant find it again) and cant get it to work. Can anyone help me out please
Donald
Inventor 2024
Sub Main Dim oDoc As DrawingDocument = ThisDoc.Document Dim oSheet As Sheet = oDoc.ActiveSheet Dim oView As DrawingView = oSheet.DrawingViews.Item(1) ' Assuming you're working with the first view ' Get the lowest Y position of all dimensions on the drawing sheet Dim lowestY As Double = GetLowestDimensionY(oSheet) ' Get the label associated with the view Dim oLabel As DrawingLabel = oView.Label ' Define the new position for the label Dim newX As Double = oLabel.Position.X Dim newY As Double = lowestY - 10 ' Adjust this value as needed for spacing ' Move the label to the new position oLabel.Move(New Point2d(newX, newY)) ' Refresh the drawing to see the changes oSheet.Update() End Sub Function GetLowestDimensionY(sheet As Sheet) As Double Dim lowestY As Double = Double.MaxValue For Each oDim As GeneralDimension In Sheet.DrawingDimensions Dim dimPosition As Point2d = oDim.Position Dim dimY As Double = dimPosition.Y If dimY < lowestY Then lowestY = dimY End If Next Return lowestY End Function
Not tested!
Try to replace
' Dim dimPosition As Point2d = oDim.Position
' Dim dimY As Double = dimPosition.Y
' with
Dim dimY As Double = oDim.Text.Origin.Y
The error I'm getting is:
Error on Line 11 : Type 'DrawingLabel' is not defined.
Error on Line 19 : 'New' cannot be used on an interface.
Donald
See example, and updates in blue.
I hope this helps.
Curtis
Sub Main Dim oDoc As DrawingDocument = ThisDoc.Document Dim oSheet As Sheet = oDoc.ActiveSheet Dim oView As DrawingView = oSheet.DrawingViews.Item(1) ' Assuming you're working with the first view ' Get the lowest Y position of all dimensions on the drawing sheet Dim lowestY As Double = GetLowestDimensionY(oSheet) ' Get the label associated with the view Dim oLabel As DrawingViewLabel = oView.Label ' Define the new position for the label Dim newX As Double = oLabel.Position.X Dim newY As Double = lowestY - 1 ' Adjust this value as needed for spacing Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(newX, newY) ' Move the label to the new position oLabel.Position = oPoint ' Refresh the drawing to see the changes oSheet.Update() End Sub Function GetLowestDimensionY(sheet As Sheet) As Double Dim lowestY As Double = Double.MaxValue For Each oDim As GeneralDimension In sheet.DrawingDimensions Dim dimPosition As Point2d = oDim.Text.Origin Dim dimY As Double = dimPosition.Y If dimY < lowestY Then lowestY = dimY End If Next Return lowestY End Function
Hi Again @Curtis_Waguespack
The rule you amended above will move the view label of the 1st base view only a set distance below the lowest dimension on the whole drawing. if there is another view, with dimensions (In the Y direction), that is lower then the base view the label of the base view will move below tat other view.
I have changed the rule (See below) to move all the view labels but its moving them all based on the rule dim above and places them in line with each other.
What I would like is the rule above to run on only 1 view at a time, and move the view label based on that view only.
i hope this is making sense?
new rule:
Public Sub Main Call RepositionDrawingViewLabels End Sub Private Sub RepositionDrawingViewLabels() 'Set a reference to the drawing document. 'This assumes a drawing document is active. Dim oApp = ThisApplication Dim oDoc As DrawingDocument oDoc = oApp.ActiveDocument 'Set a reference to the active sheet. Dim oActiveSheet As Sheet oActiveSheet = oDoc.ActiveSheet 'Set a reference to the TransientGeometry on active sheet. Dim oTG As TransientGeometry oTG = oApp.TransientGeometry 'This Drawing Document Select Set Dim oSelectset As SelectSet = oDoc.SelectSet oSelectset.Clear() Dim oSheet As Sheet = oDoc.ActiveSheet Dim oViews As DrawingViews = oActiveSheet.DrawingViews Dim oView As DrawingView = oSheet.DrawingViews.Item(1) ' Assuming you're working with the first view For Each oView In oViews oSelectset.Select(oView) 'Get the lowest Y position of all dimensions on the drawing sheet Dim lowestY As Double = GetLowestDimensionY(oSheet) 'Get the label associated with the view Dim oLabel As DrawingViewLabel = oView.Label 'Define the new position for the label Dim newX As Double = oLabel.Position.X Dim newY As Double = lowestY - 1 ' Adjust this value as needed for spacing Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(newX, newY) 'Move the label to the new position oLabel.Position = oPoint 'Refresh the drawing to see the changes oSheet.Update() Next iLogicVb.UpdateWhenDone = True End Sub Function GetLowestDimensionY(sheet As Sheet) As Double Dim lowestY As Double = Double.MaxValue For Each oDim As GeneralDimension In sheet.DrawingDimensions Dim dimPosition As Point2d = oDim.Text.Origin Dim dimY As Double = dimPosition.Y If dimY < lowestY Then lowestY = dimY End If Next Return lowestY End Function
Donald
