Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Place component (ipt) in a assembly (iam) using VB.NET
6 REPLIES 6
1707 Views, 6 Replies
How can we place a component (ipt) with specific coordonates in a assembly (iam), using VB.NET?
Thank's!
6 REPLIES 6
MechMachineMan
By starting with API help.
"C:\Program Files\Autodesk\Inventor 2016\Local Help\admapi_20_0.chm"
Once you get in there, you will probably see that you need a Transformation matrix to define the position of the part within the context of the assembly. This means that you will have to use UnitsOfMeasure to perform necessary conversions from database units (cm) to your working units.
Also, you will likely need to use TransientGeometry to CreateMatrix for if you plan on using/changing a matrix.
Good luck!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
in reply to: MechMachineMan
Can you be more precise?  Exemples will do the job.
Thank's!
Owner2229
Hi, you can try this. It'll place specified part in currently open assembly.
Red-highlighted values (1, 2, 1) are used to set the position of the placed part. They are in "cm".
' Exit sub if the document isnt assembly
If InventorApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
' Specify part to be added
Dim oFile As String = "C:\SomePath\MyPart.ipt"
' Get curently open document Dim oDoc As Inventor.AssemblyDocument = InventorApplication.ActiveDocument
' Create Matrix Dim oTG As Inventor.TransientGeometry = InventorApplication.TransientGeometry Dim oMatrix As Inventor.Matrix = oTG.CreateMatrix Call oMatrix.SetToRotation(3.14159265358979 / 4, oTG.CreateVector(0, 0, 1), oTG.CreatePoint(0, 0, 0)) Call oMatrix.SetTranslation(oTG.CreateVector(1, 2, 1), True)
' Add the part to the assembly
Dim oOcc As Inventor.ComponentOccurrence oOcc = oDoc.ComponentDefinition.Occurrences.Add(oFile, oMatrix)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
in reply to: Owner2229
Thank's Mike, it work!
jpchaisson
i know this post is old, but can someone explain the reason for needing a Matrix to place a component?
is there a way to place it by mouse-click like the normal place command?
Jeremy
I'm interested in this too. Placing by Matrix is fine, but having a UI control like the default placement one would be great.
