Hi, I know I have seen this done but I have not messed with ilogic in a long time so im a bit rusty.
I am using a snipit of code I found
Dim oCSB As New ArrayList 'Create an Array Dim UserParam As UserParameters 'Get the Parameters UserParam = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters For Each Item In UserParam 'Write Paramters to Array oCSB.Add(Item.Name) '2nd Option - Just the Parameter names, no values Next
To select from a user parameter text list for materials specification.
The code above is providing a form with a drop down from which I can select as desired. But now I need to pass the selected value to a custom iproperty for use in drawings and such.
Ideally, I would have a drop down list in the custom iproperty to begin with and not need to store the list in a user parameter but that from what I have been able to find, is apparently not supported although I could swear I have seen a drop down list in a custom iproperty before, however, I have not been able to find anything on this idea, hence this approach.
As I say. its been a long time so if someone could help with passing this from a list to a string that I can put in a custom iproperty that would be greatly appreciated.
Thanks in advance.
Rick
