Pass parameter value to custom iproperty
ricksmithYGQR7
ricksmithYGQR7
Hi, I know I have seen this done but I have not messed with ilogic in a long time so im a bit rusty.
I am using a snipit of code I found
Dim oCSB As New ArrayList 'Create an Array
Dim UserParam As UserParameters 'Get the Parameters
UserParam = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
For Each Item In UserParam 'Write Paramters to Array
oCSB.Add(Item.Name) '2nd Option - Just the Parameter names, no values
Next
 To select from a user parameter text list for materials specification.
The code above is providing a form with a drop down from which I can select as desired. But now I need to pass the selected value to a custom iproperty for use in drawings and such.
Ideally, I would have a drop down list in the custom iproperty to begin with and not need to store the list in a user parameter but that from what I have been able to find, is apparently not supported although I could swear I have seen a drop down list in a custom iproperty before, however, I have not been able to find anything on this idea, hence this approach.
As I say. its been a long time so if someone could help with passing this from a list to a string that I can put in a custom iproperty that would be greatly appreciated.
Thanks in advance.
Rick
bradeneuropeArthur
Is this what you searching for:
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
ricksmithYGQR7
Actually yes and that was my first thought, but alas...
exporting a user param is apparently not an option in 2021, however, we will be migrating to the 2023 software soon.
bradeneuropeArthur
Than use this:
Dim p As PartDocument = ThisDoc.Document
Dim pm As Parameter = p.ComponentDefinition.Parameters.UserParameters.Item("Test")
Dim cp As Inventor.Property
Try
 cp = p.PropertySets.Item(4).Item(pm.Name)
 cp.Expression = pm.Value
 Catch
cp = p.PropertySets.Item(4).Add(pm.Value,pm.Name)
End Try
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
