Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
.Net developertools.msi install
3 REPLIES 3
Hubert_Los
627 Views, 3 Replies
Hubert_Los
1) I can't install developertools.msi When I try to do this, I get the error message: "Could not find any version od Microsoft Visual Studio"
I have Visual Studio 2022 and Inventor 2019
2) I thought I didn't need to install it, because  I found and opened a simple sample from: https://knowledge.autodesk.com/search-result/caas/simplecontent/content/lesson-1-the-basic-plug--E2-...
Everything works but when debugging locals tree is not the same as in VBA editor in Inventor
Same problem as in this topic:    https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/vb-net-locals/m-p/10124791#M121584
Is it normal?
Is it normal?
3 REPLIES 3
bradeneuropeArthur
For which inventor version?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Arthur Knoors
Hubert_Los
Inventor 2019
"I have Visual Studio 2022 and Inventor 2019"
Inventor 2019
JelteDeJong
in reply to: Hubert_Los
JelteDeJong
According to this article, the developertools.msi from Inventor 2020 is only usable with Visual Studio 2017. Therefore I expect that the developertools.msi from Invent or 2019 is also only working with Visual Studio 2017.
Jelte de Jong
Blog: hjalte.nl - github.com
Jelte de Jong
