2 Hours ago I posted a post concerning my pdf ilogic snippet which doesnt work in 2019, but were ok in 2016. Could someone please explain what has happend to my post
Solved by bradeneuropeArthur. Go to Solution.
That is strange!
What was the topic Title?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
If I can remember correctly something containing these words (snippet, pdf, Ilogic, error ). I had attached a *.jgp with my error message, and I did implement my ilogic code in my post
I can't find anything related to your account-name, regarding this!
This seems to be your first topic/post nothing more!
Seems that something went wrong.
Think that you need to add it again.
Arthur Knoors
