Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Moving camera to drawingview
5 REPLIES 5
Jef_E
946 Views, 5 Replies
I am trying to move the camera to a specific drawing view. But for some reason the camera gives a perspective image..
What am I doing wrong? It's my first time working the camera.. 😄
        Dim oCamera As Camera = m_inventorApplication.ActiveView.Camera
        oCamera.ViewOrientationType = ViewOrientationTypeEnum.kFrontViewOrientation
        oCamera.Eye = oTG.CreatePoint(oView.Position.X, oView.Position.Y, 0)
        oCamera.Target = oTG.CreatePoint(oView.Position.X, oView.Position.Y, 0)
        oCamera.ApplyWithoutTransition()
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
5 REPLIES 5
MechMachineMan
in reply to: Jef_E
"Views" are anything within the graphical window in inventor.
Your code is simply accessing THAT view.
What you want is to dive into a specific DrawingView and tweak the camera object associated with that DrawingView.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Jef_E
in reply to: MechMachineMan
Yes @MechMachineMan And how can I do that? As you see I am failing to do so.
I can move my camera object, but it does not stay parallel to my drawing sheet.
Inventor 2014 SP2
MechMachineMan
in reply to: Jef_E
I misunderstood what you are trying to do.
However, the issue is that you are setting your eye and target to be the same point, which doesn't logically make sense. It means that the 2 points are exactly the same and the vector between them is undefined/arbitrary.
You need to supply a Z value to the eye, as I did below:
Dim oView As DrawingView
oView = ThisApplication.ActiveDocument.ActiveSheet.DrawingViews(1)
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
Dim oCamera As Camera = ThisApplication.ActiveView.Camera
oCamera.Eye = oTG.CreatePoint(oView.Position.X, oView.Position.Y, oCamera.Eye.Z)
Justin K
Jef_E
@MechMachineMan Cheers!
Now one more thing, how can I set the zoom distance? What I want is to zoom that the view rangebox occupies most of the camera. If you get what I mean 🙂
Greetings.
Inventor 2014 SP2
MechMachineMan
in reply to: Jef_E
Just like this....
Kinda like in this previous post I found asking to do the same thing....
https://forums.autodesk.com/t5/inventor-customization/zoom-to-view-in-drawing/td-p/2655306
SyntaxEditor Code Snippet
oOversizePct = 2
With oCamera
	.Eye = oTG.CreatePoint(oView.Position.X, oView.Position.Y, .Eye.Z)
	.SetExtents(oOversizePct * oView.Width, oOversizePct * oView.Height )
End With
Justin K
Technology Administrators
