Why is it that Autodesk can't actually create a function that migrates ALL settings from one version to another?
Maybe it's the 04.00 start today, but I really don't have time for this.
How do I get the parameters to display as per the image below:
Solved by arkelec. Go to Solution.
What are your exactly referring to?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
The solution was to enable the Status Bar. Although why this could not be included under the migration is beyond me. When it's good, Inventor is good but by God when it's bad........there are simply too many fragmented locations for enabling functions & storing data/user files.
