Monitor for left click event
dylanTEV9W
1,590件の閲覧回数
19件の返信
メッセージ1/20
dylanTEV9W
Hi All I'm trying to learn how to monitor for events from within Inventor.
I'm running the following code which is modified from the cancel a double click API (link: example http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-A7B286A0-5234-49B0-8C89-00411A6B1173)
'Option Explicit is turned on above my imports at the start of my code.
Private Sub Class_initializer()
OUIEvents = _invApp.CommandManager.UserInputEvents
End Sub
Private Sub OUIEvents_OnClick(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View, ByVal AdditionalInfo As NameValueMap, HandlingCode As HandlingCodeEnum)
If Button = 1 Then '1 is the Enum value for the left mouse button.
Debug.Print("Left click detected ")
End If
End Sub
Running the code doesn't cause the debug line to print though when i left click. Any help would be greatly appreciated!
0 件のいいね
解決済み
1,591件の閲覧回数
19件の返信
返信 (19)
メッセージ2/20
bradeneuropeArthur
the on "clickevent" is not implemented:
but the "OnDoubleClick: is...:
Private Sub OUIEvents_OnDoubleClick(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View, ByVal AdditionalInfo As NameValueMap, HandlingCode As HandlingCodeEnum)
MsgBox ""
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
0 件のいいね
メッセージ3/20
dylanTEV9W
Thanks For Explaining that. I modified the code to the version below but I'm still not seeing anything happen. I know I must be missing something but I'm not sure what is?
Private WithEvents OUIEvents As UserInputEvents
End Sub
MsgBox("")
Debug.Print("")
End Sub
0 件のいいね
メッセージ4/20
bradeneuropeArthur
What are you using vba; vb.net; or ilogic
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ5/20
dylanTEV9W
I'm using VB.Net.
0 件のいいね
メッセージ6/20
bradeneuropeArthur
within an add in or standalone app?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ7/20
dylanTEV9W
As a standalone application.
0 件のいいね
メッセージ8/20
bradeneuropeArthur
did you create a separate class for the events?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ9/20
dylanTEV9W
No I was trying to run it out of my base application class. Will I need a seperate class to handle events?
0 件のいいね
メッセージ10/20
bradeneuropeArthur
better yes, but if it is in a class already it must work too.
please keep reading.
put this in your class:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ11/20
bradeneuropeArthur
in your class:
Public ThisApplicationa As Inventor.Application
Public WithEvents OUIEvents As UserInputEvents
Public WithEvents inev As ApplicationEvents
Public Sub Activate()
Set ThisApplicationa = ThisApplication
OUIEvents = ThisApplicationa.CommandManager.UserInputEvents
MsgBox ThisApplicationa.ActiveDocument.FullDocumentName
End Sub
Debug.Print ("Left click detected ")
End If
End Sub
Private Sub Class_Initialize()
MsgBox "ini"
End Sub
Public Sub OUIEvents_OnActivateCommand(ByVal CommandName As String, ByVal Context As NameValueMap)
MsgBox CommandName
End Sub
Public Sub OUIEvents_OnDoubleClick(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View, ByVal AdditionalInfo As NameValueMap, HandlingCode As HandlingCodeEnum)
MsgBox "clil=ck"
End Sub
keep reading....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ12/20
bradeneuropeArthur
and this this in your program like userform or else
Dim a  As New Class1
Public Sub main()
Set a = New Class1
a.Activate
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ13/20
dylanTEV9W
Okay I will try running your code right now. Thank you for all of your help so far!
0 件のいいね
メッセージ14/20
bradeneuropeArthur
maybe you need to change this:
' To this depening of your app
Set ThisApplicationa = getobject("inventor.application")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ15/20
bradeneuropeArthur
or second you could use:
Dim a  As Class1
Public Sub main()
Set a = New Class1
Dim x As Application
Set x = GetObject("inventor.application")
Call a.Activate(x)
End Sub
and this in your class:
Public Sub Activate(ThisApplication As Inventor.Application)
Set OUIEvents = ThisApplicationa.CommandManager.UserInputEvents
Hope it works with your app to.
For me it works...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ16/20
dylanTEV9W
I'm converting from vba to vb.net so I can run it in my application. I will post if I'm successful along with the converted code.
0 件のいいね
メッセージ17/20
bradeneuropeArthur
Good job to convert it to vb.net.....
I have this code provided also ready for vba. If you need I can provide it too.
Let me know if you need help.
At the moment I am far from my desk.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ18/20
dylanTEV9W
I think I'm still missing something here. I'm still very unclear on what needs to happen for my app. to constantly be watching for and respond to events within Inventor. I'm able to make Activate() run within my application but only by triggering it within another event. But I'm not sure what I need to make my application constantly look for the click event? This is what I have so far but it doesn't seem to detect left click events from inventor.
lass Class1
Public WithEvents Inev As ApplicationEvents
Public Event XEvent()
ThisApplicationa = Marshal.GetActiveObject("Inventor.Application")
'MsgBox(ThisApplicationa.ActiveDocument.FullDocumentName)
End Sub
Public Sub OUIEvents_OnClick(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View, ByVal AdditionalInfo As NameValueMap, HandlingCode As HandlingCodeEnum)
RaiseEvent XEvent()
End If
End Sub
MsgBox("ini")
End Sub
MsgBox(CommandName)
End Sub
MsgBox("clil=ck")
End Sub
End Class
Public Class Form1
Dim WithEvents cls1 As Class1 = New Class1()
Private Sub ABC() Handles cls1.XEvent
MsgBox("Click Recieved")
End Sub
Private Sub MyApplication_Startup(ByVal sender As Object, ByVal e As Object) Handles Me.Activated
cls1.Activate()
End Sub
End Class
0 件のいいね
メッセージ19/20
dylanTEV9W
Okay so I did some more revision on my code. I'm currently able to detect and react to events from the UserInputEvents class but not the mouse events class. This is an issue for me since I'm trying to only detect a single click in Inventor with my code. Right now when I try to monitor for an event from the MouseEvents class nothing happens. This is what I have coded so far. Any more help that can be offered would be greatly appreciated!
Class EventClass
'Public class members
Public _invApp As Inventor.Application 'Get inventor application
Public WithEvents User_input_events As UserInputEvents 'Create a public member with events for the inventor UserInputEvents
Public WithEvents App_events As ApplicationEvents 'Create a public member with events for the inventor ApplicationEvents
Public WithEvents Mouse_events As MouseEvents
Public WithEvents Interaction_events As InteractionEvents
'Public sub routines
Public Sub Activate() 'Activates the event class and assigns objects to the ThisApplication and user_input_events members.
_invApp = Marshal.GetActiveObject("Inventor.Application") 'Assigns the inventor application.
User_input_events = _invApp.CommandManager.UserInputEvents 'Assign the user input events.
Interaction_events = _invApp.CommandManager.CreateInteractionEvents
Mouse_events = Interaction_events.MouseEvents
Mouse_events.MouseMoveEnabled = True 'Enable the ability to fire mouse move events.
End Sub
'Private sub routines
Private Sub OnLeftClick() Handles Mouse_events.OnMouseClick 'Private sub fires when the mouse is clicked in the active inventor doc.
Debug.Print("A mouse button was clicked")
End Sub
Private Sub User_input_events_OnDrag(DragState As DragStateEnum, ShiftKeys As ShiftStateEnum, ModelPosition As Point, ViewPosition As Point2d, View As View, AdditionalInfo As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles User_input_events.OnDrag 'Private sub fires when something in the active inventor doc is selected.
Dim select_set As SelectSet = _invApp.ActiveDocument.SelectSet 'Define a select set member.
Dim selected_face As Face 'Define a face member
If select_set.Item(1).Type = ObjectTypeEnum.kFaceObject Then
'Debug.Print("looks like you're trying to drag a face")
selected_face = select_set.Item(1)
Debug.Print(ViewPosition.X)
Debug.Print(ViewPosition.Y)
End If
End Sub
Private Sub Mouse_events_OnMouseMove(Button As MouseButtonEnum, ShiftKeys As ShiftStateEnum, ModelPosition As Point, ViewPosition As Point2d, View As View) Handles Mouse_events.OnMouseMove
Debug.Print("hi")
'Debug.Print(Button)
End Sub
End Class
0 件のいいね
メッセージ20/20
dylanTEV9W
解決済み
So when I was combing through the On Drag example code I found the solution I wasn't telling the interaction_events to start. Here is the completed code. Note that once the user hits escape the interaction events deactivate and stop looking for clicks. If you're trying to do something similar to this and are confused and having trouble like I was hopefully this will provide some answers on how to do this with VB.Net.
Class EventClass
Interaction_events = _invApp.CommandManager.CreateInteractionEvents 'Create the interaction events object.
Mouse_events = Interaction_events.MouseEvents 'Assign the mouse events.
Interaction_events.Start() 'Activates the interaction events so that they can be passed to this app.
End Sub
End If
End Sub
Private Sub Mouse_events_OnMouseClick(Button As MouseButtonEnum, ShiftKeys As ShiftStateEnum, ModelPosition As Point, ViewPosition As Point2d, View As View) Handles Mouse_events.OnMouseClick
If Button = MouseButtonEnum.kLeftMouseButton Then
Debug.Print("The left Mouse button was clicked.")
End If
End Sub
'Private Sub OnClick() Handles app_events.
End Class
