Hello!
I'm trying to create model states and modify their iProperties programmatically.
I'm getting errors when I try to access the model states' 'Design Tracking Properties' PropertySet.
How can I initialize it or otherwise get to the point where I can modify the values here?
Solved by meGVGMF. Go to Solution.
Solved by WCrihfield. Go to Solution.
Hi there,
I am sharing piece of code from a helpful article.
Sub ModelStateProps()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisDocument ''You can use every document you want to use
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
Dim oModelStates As ModelStates
Set oModelStates = oCompDef.ModelStates
‘Fetch the required Model State from the collection
Dim oModelState As ModelState
Set oModelState = oCompDef.ModelStates("YOUR_MODEL_STATE_NAME")
'Activate the model state
oModelState.Activate
' Get the design tracking property set for our model state.
Dim propSet As Inventor.PropertySet
Set propSet = oPartDoc.PropertySets.Item("Design Tracking Properties")
' Get the Stock Number property.
Dim prop As Property
Set prop = propSet.Item("Stock Number")
' Set the Member Edit Scope
oModelStates.MemberEditScope = kEditActiveMember 'kEditAllMembers for all members
'Set the value
prop.Value = "VALUE"
End Sub
So you can use this one. If you want to read more about topic, author also wrote really nice article:
https://adndevblog.typepad.com/manufacturing/2022/01/working-with-propertysets-and-model-states.html
Devrim
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
use it this way:
Sub Main()
oPartDoc = ThisDoc.Document ''You can use every document you want to use
'Fetch the required Model State From the collection
oModelState = oCompDef.ModelStates("Model State1")
Dim prop As Inventor.Property
'Set the value
prop.Value = "001"
End Sub
Arthur Knoors
Yeah I was just working on that! Take a look:
Sub Main()
Const sDTPropSetName As String = "Design Tracking Properties"
Const sDTPropSetInternalName As String = "{32853F0F-344-11D1-9E93-0060B03C1CA6}"
Dim oDoc As PartDocument = ThisDoc.Document
Dim oModelStates As ModelStates = oDoc.ComponentDefinition.ModelStates
oModelStates(1).Activate
oModelStates.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
For i As Integer = oModelStates.Count To 2 Step -1
oModelStates(i).Delete
Next
oModelStates.Add
Dim oMS As ModelState = oModelStates(oModelStates.Count)
Dim oDTPropSet As PropertySet
Dim oMSDoc As PartDocument = oMS.Document
Dim bNeedsInit As Boolean = False
If oMSDoc.PropertySets.PropertySetExists(sDTPropSetInternalName, oDTPropSet) Then
oDTPropSet = oMSDoc.PropertySets.Add(sDTPropSetName, sDTPropSetInternalName)
bNeedsInit = True
End If
Const sPropName As String = "Stock Number"
Const iPropId As Integer = 55
Const sPropVal As String = "Test"
Try
oDTPropSet(sPropName).Value = sPropVal
Catch
oDTPropSet.Add(sPropVal, sPropName, iPropId)
End Try
If Not bNeedsInit Then
Exit Sub
End If
'per https://knowledge.autodesk.com/support/inventor/learn-explore/caas/simplecontent/content/add-ilogic-rule-to-event-trigger-using-external-ilogic-rule.html
Dim oTempProp As Inventor.Property = oDTPropSet.Add("", "Delete")
oTempProp.Delete
oMSDoc.Update
End Sub
It fails when checking whether the PropertySet exists because, I believe, the document within the model state is initialized as `Nothing`
The problem is that rebuilding the model when activating a model state is too costly an operation.
A possibility is to do this whenever I find the model state document uninitialized, but I'm still curious to know if it's possible to do this purely without activation.
Hi @meGVGMF. In order to avoid the complicated document references, model state activation, & setting edit member scope, you could just edit the ModelStateTable instead. It is certainly a different process, but can be really nice in some scenarios, plus you can easily make changes to multiple model states at one time, because they are all in that table together. You just need to know the layout of that table and how to navigate it.
Wesley Crihfield
(Not an Autodesk Employee)
Yeah that's been something I've been meaning to look into.
You don't happen to have a reference on basic API functions handy, do you?
Unfortunately, many of the URL's in the Inventor online help area for the ModelState related API Objects (and many other newer additions to the online help) are still screwed up, but I think they are 'slowly' working on fixing them.
Once you get to the ModelStates object (Document.ComponentDefinition.ModelStates), that object has a property called ModelStateTable, which returns a ModelStateTable object. This object has two properties (TableColumns & TableRows). You can use those as a starting point for looping or navigating through the tables columns & rows, as you would expect. If specifying a specific row or column using Item(), you can either specify its Index (Integer), or the String type value that represents the column's heading, or row's member name (the name of the ModelState). Most of the object properties in the table are ReadOnly, but the ModelStateTableCell.Value is Read/Write. And the ModelStateTableColumn object has a useful Property named ReferenceDataType, which returns a variatant of the iComponentColumnTypeEnum, which helps inform you of what type of data that column is for.
Wesley Crihfield
Also, I just noticed that within the code you posted in message 5, I see that you were attempting to 'Add' an iProperty into the "Design Tracking Properties" set. That is not possible. The first 3 PropertySet objects in every Inventor document are fixed size, so you can not add or remove any of the properties in those sets, or rename any of them. Many of them even have ReadOnly values, but some have Read/Write values. The fourth PropertySet is pretty much always the 'custom' one, named "Inventor User Defined Properties", and that set does not have any properties, by default, until you add them. You can add or remove properties in that 'custom' set all you want. The link referenced in a commented line within your code is talking about a special PropertySet that is 'hidden' by default, by Autodesk, and it does not even exist in a document until you have used the Event Triggers dialog to add rules to events within that document (or created it by code, which is still a bit buggy). That PropertySet is very unique, and is used by Autodesk internally. It was only found by Inventor users by trial/error/accident back around 2012-2013.
Wesley Crihfield
Fair enough. I had other use cases involving the custom PropertySet. But that code never made it that far, anyway.
I was wondering, though, is it possible to add a column to the ModelStateTable object, somehow?
Actually I've just figured something out. I'm changing the value of something that's about to change, via `iProperties.Value`, to have the table generate the column for me.
