Measure.ExtentsLength from a part to drawings
7 REPLIES 7
Message 1 of 8
1464 Views, 7 Replies
Is it possible to use the Measure.ExtentsLength in a drawing to get model dimensions?
What I am trying to do is get the overall dimensions of the model and place them in a sketch block in the drawings so our machinist can easily reference the stock material.  I have a solution for the other steps required but I can't figure out how to get the overall model dimensions.
Thanks for the support,
Steve
7 REPLIES 7
Message 2 of 8
mrattray
Did you try the DrawingDimension.ModelValue property?
Even better you could try referencing an exported model parameter.
Mike (not Matt) Rattray
Message 3 of 8
in reply to: mrattray
Would the ModelValue property take into account extrusions stack one on the other to give the overall or would it give just the base distance?
I think my best bet is to reference a model parameter.  I just have to figure out how to export the parameters I want.
I also  should have mentioned I would like to do this in iLogics and not VBA but if I have to it would not be the worst thing.
Steve
Message 4 of 8
mrattray
Just make a user parameter then and make it's value the sum of your stacked extrusions.
Message 5 of 8
Did anybody find a solution for this? I'm trying to get the Extents Length of a model from the drawing view as well, for use in automatically setting the view scale.
Message 6 of 8
mrattray
One option is to make the part a sheet metal part (if it's not already) and create a flat pattern. It won't hurt anything to make something that's not even thinking about being a sheet metal part one. Once you have a "flat pattern" (quotes because it might just be another not so flat view of the part) you'll have access to the flat pattern extents properties. This will give you two of the bounding box dimensions of the part that will automatically update whent he part changes. As far as the third dimension: if it's not really sheet metal then there's not much we can do about it besides my earlier suggestion.
Message 7 of 8
MechMachineMan
You can always just open the part invisible and get the rangebox of it and then create a list of Length, Width, Thickness, as below.
oSheet = ThisApplication.ActiveDocument.ActiveSheet
oDrawingView = oSheet.DrawingViews.Item(1)
oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
oDoc = ThisApplication.Documents.Open(oModel.FullFileName, False)
oCompDef = oDoc.ComponentDefinition
oBOX = oCompDef.RangeBox
oXDif = oUOM.ConvertUnits(Abs(oBOX.MaxPoint.X - oBOX.MinPoint.X), "cm", "in")
oYDif = oUOM.ConvertUnits(Abs(oBOX.MaxPoint.Y - oBOX.MinPoint.Y), "cm", "in")
oZDif = oUOM.ConvertUnits(Abs(oBOX.MaxPoint.Z - oBOX.MinPoint.Z), "cm", "in")
Dim oDIMS As New List(Of Double)
oDIMS.ADD(oXDIF)
oDIMS.ADD(oYDIF)
oDIMS.ADD(oZDIF)
oDIMS.Sort
oDIMS.Reverse
what i typically do is put the list into parameters within the part, so that I can easily format them as I wish. And have the sketched sym show those params via iProps.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 8 of 8
in reply to: MechMachineMan
Hi All,
I'm trying to get the dimensions (length, breadth, height) of all the models referenced in an assembly. I'm planning to do this using either Inventor API or Apprentice API reading the BOM of the main assembly and opening each model and executing something similar to the below code (source from Justin's reply in this thread).
var compDef = assemblyDoc.ComponentDefinition;
var rangeBox = compDef.RangeBox;
MessageBox.Show("Unit is " + assemblyDoc.UnitsOfMeasure.GetStringFromType(assemblyDoc.UnitsOfMeasure.LengthUnits));
//to do: make changes based on units
var length = (rangeBox.MaxPoint.X - rangeBox.MinPoint.X) / 2.54;
var width = (rangeBox.MaxPoint.Y - rangeBox.MinPoint.Y) / 2.54;
var height = (rangeBox.MaxPoint.Z - rangeBox.MinPoint.Z) / 2.54;
MessageBox.Show(length + Environment.NewLine + width + Environment.NewLine + height);
But when I run the below ilogic rule on random models to check the output, for some models some dimensions differ by 1 or 2 inches
SyntaxEditor Code Snippet
MessageBox.Show(Measure.ExtentsLength, "Length")
MessageBox.Show(Measure.ExtentsWidth, "Width")
MessageBox.Show(Measure.ExtentsHeight, "Height")
Model1:
program (in)iLogic (in)
35.8334.8643055
32.81727.3675394
9696
Model 2:
18.750418.75
16.76816.7287
3.8282.9295
My questions are:
1. Why this difference in dimensional values? I checked the work features on these models, they were turned off.
2. Is there a better solution for my original problem? Get the dimensions (length, breadth, height) of all the models referenced in an assembly.
Rekha.
Tags (2)
