Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Make holefeature based on sketchline and offset
1 REPLY 1
juliengoertz
104 Views, 1 Reply
I made some code to create a rectangular pattern based on the directions of sketchlines. Now i would like to create the hole that needs to be used in the pattern based on the same lines. So ideally i would create a point based on the sketchlines + offset which i then use to make a hole, which i then use to create the pattern. But i can't find any inspiration to do this. Is there anyone that could help me a bit?
The situation is as follows. The green lines in the following screenshot is my selectionset, from which i can get the sketchlines. The placed point is where i would like to have my point which i can use to make a hole. Which i would like to be placed automatically:
Thanks in advance!
1 REPLY 1
A.Acheson
in reply to: juliengoertz
Hi @juliengoertz
If i am doing any of this part automation I generally like to go into the API samples and check if there is anything that fits the bill. In this case I search part and hole feature sample. You can pick what you need from the sample when you convert to VB.NET ...
Below is the VBA code.
Public Sub HoleSample()
    ' Create a new part document, using the default part template.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                 ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Set a reference to the component definition.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    ' Create a new sketch on the X-Y work plane.
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes.Item(3))
    ' Set a reference to the transient geometry object.
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    ' Create a rectangle on the sketch.
    Call oSketch.SketchLines.AddAsTwoPointRectangle( _
                                        oTransGeom.CreatePoint2d(0, 0), _
                                        oTransGeom.CreatePoint2d(6, 4))
    ' Create the profile.
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    ' Create an extrusion.
    Dim oExtrudeDef As ExtrudeDefinition
    Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
    Call oExtrudeDef.SetDistanceExtent("2 cm", kNegativeExtentDirection)
    Dim oExtrude As ExtrudeFeature
    Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
    ' Create a new sketch to contain the points that define the hole centers.
    ' Create an object collection for the hole center points.
    Dim oHoleCenters As ObjectCollection
    Set oHoleCenters = ThisApplication.TransientObjects.CreateObjectCollection
    ' Add two points as hole centers.
    oHoleCenters.Add oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(1, 1))
    oHoleCenters.Add oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(5, 1))
    ' Create the hole feature.
    Call oCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent( _
                            oHoleCenters, "1 cm", kPositiveExtentDirection)
    ' Define tap information.
    Dim oHoleTapInfo As HoleTapInfo
    Set oHoleTapInfo = oCompDef.Features.HoleFeatures.CreateTapInfo( _
                            True, "ANSI Unified Screw Threads", _
                            "7/16-14 UNC", "1B", False, "1 cm")
    ' Create a new sketch for the tapped hole centers.
    ' Create a new object collection for the hole center points.
    oHoleCenters.Add oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(1, 3))
    oHoleCenters.Add oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(5, 3))
                            oHoleCenters, oHoleTapInfo, kPositiveExtentDirection)
End Sub
Regards
Alan
Technology Administrators
