I made some code to create a rectangular pattern based on the directions of sketchlines. Now i would like to create the hole that needs to be used in the pattern based on the same lines. So ideally i would create a point based on the sketchlines + offset which i then use to make a hole, which i then use to create the pattern. But i can't find any inspiration to do this. Is there anyone that could help me a bit?
The situation is as follows. The green lines in the following screenshot is my selectionset, from which i can get the sketchlines. The placed point is where i would like to have my point which i can use to make a hole. Which i would like to be placed automatically:
Thanks in advance!
If i am doing any of this part automation I generally like to go into the API samples and check if there is anything that fits the bill. In this case I search part and hole feature sample. You can pick what you need from the sample when you convert to VB.NET ...
Below is the VBA code.
Public Sub HoleSample()
' Create a new part document, using the default part template.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
' Create a new sketch on the X-Y work plane.
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes.Item(3))
' Set a reference to the transient geometry object.
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
' Create a rectangle on the sketch.
Call oSketch.SketchLines.AddAsTwoPointRectangle( _
oTransGeom.CreatePoint2d(0, 0), _
oTransGeom.CreatePoint2d(6, 4))
' Create the profile.
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
' Create an extrusion.
Dim oExtrudeDef As ExtrudeDefinition
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
Call oExtrudeDef.SetDistanceExtent("2 cm", kNegativeExtentDirection)
Dim oExtrude As ExtrudeFeature
Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
' Create a new sketch to contain the points that define the hole centers.
' Create an object collection for the hole center points.
Dim oHoleCenters As ObjectCollection
Set oHoleCenters = ThisApplication.TransientObjects.CreateObjectCollection
' Add two points as hole centers.
oHoleCenters.Add oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(1, 1))
oHoleCenters.Add oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(5, 1))
' Create the hole feature.
Call oCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent( _
oHoleCenters, "1 cm", kPositiveExtentDirection)
' Define tap information.
Dim oHoleTapInfo As HoleTapInfo
Set oHoleTapInfo = oCompDef.Features.HoleFeatures.CreateTapInfo( _
True, "ANSI Unified Screw Threads", _
"7/16-14 UNC", "1B", False, "1 cm")
' Create a new sketch for the tapped hole centers.
' Create a new object collection for the hole center points.
oHoleCenters.Add oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(1, 3))
oHoleCenters.Add oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(5, 3))
oHoleCenters, oHoleTapInfo, kPositiveExtentDirection)
End Sub
