Im really confused...
I have a derived assembly part that needs to open the main assembly with suppressed cable harness parts.
Now the open parent assembly code only opens the assembly on a master level.
I had a LOD called custom where i had suppressed Cable harness assemblies depending on the code selection etc...
oAsmDef.RepresentationsManager.LevelOfDetailRepresentations("Custom").activate
Now this is creating a so called model states...
the issue is i then derive many configurations into a part from this assembly and i use this code to obtain a few details from the parent assembly ( iproperties, etc...)
using this..
For Each oDerAssemblyComp In Doc_P.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents oDerAssemblyCompDef = oDerAssemblyComp.Definition Full_File_Name = oDerAssemblyComp.ReferencedDocumentDescriptor.FullDocumentName Next oDoc_Parent = ThisApplication.Documents.Open(Full_File_Name, False) oAsmDef = oDoc_Parent.ComponentDefinition
But this only opens the Master version of the parent assembly so now i cant get any details from the parent assembly for some reason...
Why was LOD replaced with model states?
I cant suppress Harness parts in Master level of model states so Im left with nothing it seems???
Please see screenshots attached...
Sorry but I don't understand the problem you have.
I don't see any code that pulls properties from the one to the other file.
Could you please share your complete code here to investigate and help you further.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Well i have two problems..
the code is extensive because there are more than a few external rules completing a few tasks.
Ill have to clean them and take out all references first and create a copy of the assembly etc.. just to show you.
But here is a screen cast link with another problem i think also caused by model states.
I hide visibility of components on the parent assembly and i let the designer access it through a derived part.
the issue is that derived part cant include workplanes anymore for some reason. i need those planes for connecting them .
so its either a master view with non hidden parts or a default view linked to the parent assembly without planes.
I derived it including all workfeatures but for some reason this is not including them in Inventor 2022.
