Is there a table which lists the Name and DisplayName for assets?
oransen
oransen
If I've understood the Name of a material asses is the fixed international name of that material, and the DisplayName of the asset changes with the language used.
For example in my program I can see that an Inventor part has a Name of "Metal-022" and a DisplayName of "Copper - Satin".
Is there a table or method of getting all the Names and their corresponding DisplatNames in the various languages?
bradeneuropeArthur
What version of inventor?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
oransen
Inventor Proffesional 2017...
smilinger
You may want to check these files:
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\materialmapping.xml
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\proteinmapping.xml
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\externalmaterialmapping.xml
or these files:
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\Materials\InventorMaterialLibrary-xxx.xlf
oransen
Many thanks, all I had to do was change 2018 to 2017 and there were the files 🙂
