Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iproperties show value
5 REPLIES 5
sjoerd.van.der.eerden
348 Views, 5 Replies
hi,
I want the description of a part to reference a parameter value.
but I can't just write the parameter name cause then it wil show only the name.
considering that the value can change, I also can't write the value itself.
how can I get it to write the number instead of the name.
the name is D2 but I want it to say L200 for example.
iProperties.Value("Project", "Description") = "leiding d63 Ld2"
5 REPLIES 5
The parameter name cannot be "leiding d63 Ld2" with spaces?
Or do you mean the description must be like "Leiding" then <Parameter.value> d63 then <parameter.value> Ld2
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
the description needs to be leiding (pipe) d63 (pipe diameter) L"pipe length"
the pipe length is a changing value. so I want the description to match the actual length.
the parameter that is responsible for the length is called d2
now it just shows the text I entert plus the parameter name (d2)
third one from the bottum
Hi, you can try this :
iProperties.Value("Project", "Description") = "leiding d63 L" & d2
Vincent.
wonderful,
works like a charm.
thankss
