Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
ipart break link
15 REPLIES 15
Message 1 of 16
1245 Views, 15 Replies
ipart break link
I have made a code to break link of ipart in assembly with parent factory. It works in one assembly and it doesen't work in a another. Please Help i can't find the problem
SyntaxEditor Code Snippet
    Dim asmDoc As AssemblyDocument
    asmDoc = ThisApplication.ActiveDocument
    Dim oDoc As Document = ThisDoc.Document
    Dim oCompDef As Inventor.ComponentDefinition = oDoc.ComponentDefinition
       Dim occ As Inventor.ComponentOccurrence
      Dim partCompDef1 As PartComponentDefinition
    Dim partCompDef2 As PartComponentDefinition
    Dim factoryDoc As PartDocument
    'Dim oPart As PartDocument
    Dim i As Long=1
    For Each occ in oCompDef.Occurrences
    occ = asmDoc.ComponentDefinition.Occurrences(i)
    If occ.IsiPartMember Then
        partCompDef1 = occ.Definition
        factoryDoc=partCompDef1.iPartMember.ReferencedDocumentDescriptor.ReferencedDocument
        For Each oPart In factoryDoc.ReferencedDocuments
            MessageBox.Show("Message", "Title")
            oPart.ComponentDefinition.iPartMember.BreakLinkToFactory
        Next
    End If
    i=i+1
      Next
15 REPLIES 15
Message 2 of 16
bradeneuropeArthur
What do you mean with other assembly?
Do you mean a sub assembly from the top assembly?
Or  a complete other assembly?
if you mean subassembly then you need to create a recursive loop!
let me know what you mean....
Regards
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 3 of 16
in reply to: bradeneuropeArthur
I mean a sub assembly from the top assembly....:)
Message 4 of 16
bradeneuropeArthur
then we need to modify the code a little....
keep reading, come back to it ASAP
Arthur Knoors
Message 5 of 16
My final goal is to make a code that will go throught all components of a assembly and will break the link with all the iparts factory and subassembly factories. Basicly i want to make a code that will convert all iparts and iassembly into parts.My workflow will go something like this:
Pack and go=>run code (convert(break links with factory) with all iparts and iassemblies into normal parts and assemblies)=> pack and go again
Message 6 of 16
bradeneuropeArthur
Public Sub main()
End Sub
Public Sub c(asmDoc As AssemblyDocument)
    Dim i As Long=1
    For Each occ In oCompDef.Occurrences
        factoryDoc = partCompDef1.iPartMember.ReferencedDocumentDescriptor.ReferencedDocument
        Next
    End If
    If occ.DefinitionDocumentType = kAssemblyDocumentObject Then
    Call c(occ.Definition.Document)
    End If
    i = i + 1
      Next
End Sub
Arthur Knoors
Message 7 of 16
I am a little stupid her,when i run this code in a simple assembly with two ipart members and a subiassembly member  it does nothing? When i read the code i have to add something in the main sub? What am i missing?
I am really thankfull for helping me with this code
Message 8 of 16
bradeneuropeArthur
No.
I made mistake!!
Public Sub main()
End Sub
c(asmDoc)
    Dim i As Long=1
        Next
    End If
    End If
    i = i + 1
      Next
End Sub
Arthur Knoors
Message 9 of 16
Ok so here is the problem i get when i run the code. The problem lies in the line
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 672 StartFragment: 314 EndFragment: 640 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
The error i get is "Object reference not set to an instance of an object."
I have a simple assembly with two iparts and a subiassembly. Do i need to do something in the ipart auther table or something to make it work??
Message 10 of 16
I have atached the rule with a simple assembly. Can somone please help me find the error???
Message 11 of 16
Anyone?
Message 12 of 16
Ok I am stupid. Found the problem.....
Thank you for the help brandeneurope
Message 13 of 16
bradeneuropeArthur
Your thanks are appreciated!
Arthur Knoors
Message 14 of 16
aurel_e
@Anonymous
Can you please post the right rule?
I am having the same problem "Object reference not set..."
Message 15 of 16
in reply to: aurel_e
This code was a year ago when i started learning about ipart and ilogic codeine. I think it is this one try it:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 19535 StartFragment: 314 EndFragment: 19503 StartSelection: 314 EndSelection: 314
Sub Main()
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim occ As ComponentOccurrence
isum=isum+1
Next
For i=1 To isum
occ = oDoc.ComponentDefinition.Occurrences(i)
    Dim oPCD As PartComponentDefinition
    oPCD = occ.Definition
    Dim iPM As iPartMember
    iPM = oPCD.iPartMember
    iPM.BreakLinkToFactory
End If
If occ.IsiAssemblyMember Then
    Call processAllSubOcc(occ)
    Dim oPCD As AssemblyComponentDefinition
    Dim iPM As iAssemblyMember
    iPM = oPCD.iAssemblyMember
End If
Next
iLogicVb.UpdateWhenDone = True
End Sub
' This function is called for processing sub assembly. It is called recursively' to iterate through the entire assembly tree.
Sub processAllSubOcc(ByRef occ As ComponentOccurrence)
Dim oAssemblyDoc As AssemblyDocument
oDoc = occ.Definition.Document
Dim Subocc As ComponentOccurrence
For Each Subocc In oCompDef.Occurrences
isum=isum+1
Next
For i=1 To isum
subocc = oDoc.ComponentDefinition.Occurrences(i)
If subocc.IsiPartMember Then
    oPCD = subocc.Definition
End If
If subocc.IsiAssemblyMember Then
    Call processAllSubOcc(subocc)
    oPCD = subocc .Definition
End If
Next
End Sub
Message 16 of 16
aurel_e
It works!
Thank you @Anonymous
