I have a software that, among others, creates pack'n'go for each specified order. Till version 2023, it was working fine (it still does on that version). On Inventor 2024 and now also 2025, when it's trying to pack'n'go the generated 3D, it gives me the error:
"The ordinal 345 could not be found in the dynamic link library C:\Program Files\Autodesk\Inventor 2025\Bin\Dt.dll".
Searching about it, I found that this error is similar for other software too, and there is also an unresolved subject for Navisworks in the forum. Also, I have checked any possible solution out there and still nothing.
It's crucial for our process that this gets resolved.
This file still is in the C:\Program Files\Autodesk\Inventor 2025\Bin\Dt.dll folder, correct?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
This error is also occurring in "new PackAndGoComponent()" for Inventor Professional 2024 in our environment.
We have registered support request 22668785 and confirmed that the error also occurs on the Autodesk side.
They then escalated the issue to the development team as INVGEN-79836.
This is a major issue for us as well, so we would appreciate your immediate response.
