I'm trying to get the Addin Templates, but it seems the devtools.msi isn't properly extracting/installing them?
I've tried running the command line
msiexec /i "C:\Users\Public\Documents\Autodesk\Inventor 2017\SDK\developertools.msi" /qb TARGETDIR="C:\Users\Gus\Desktop\DT"
but it keeps saying some scripts cannot be run and exiting.
Is there a way around this aside from getting the templates from someone else and manually copying them over?
Solved by MechMachineMan. Go to Solution.
Nvm...
I had it typed wrong.
msiexec /a "C:\Users\Public\Documents\Autodesk\Inventor 2017\SDK\developertools.msi" /qb TARGETDIR="C:\Users\Gus\Desktop\DT"
And I can build the solution... So that's always good!
Nvm...
@MechMachineMan wrote:Nvm...
msiexec /a "C:\Users\Public\Documents\Autodesk\Inventor 2017\SDK\developertools.msi" /qb TARGETDIR="C:\Users\Gus\Desktop\DT"And I can build the solution... So that's always good!
I run the "developertools.msi" in command window by using your solution,
but I can‘t find Autodesk Inventor Addin in the VS,
can you help me ?
can you help me ?
