Incorrect BrowserNode.Parent, method ignores folder belonging to assembly
CattabianiI
CattabianiI
I'm experiencing this problem that seems a bug, trying to iterate thru assembly structure looking for folders too.
TL;DR
Traversing down with BrowserNode.BrowserNodes property works;
Traversing up with BrowserFolder.Parent property doesn't work if this folder is nested in a non active assembly: is this a bug?
Long version with two code snippet, useful for testing.
This is how my algorithm works: for every occurence I get the linked BrowserNode, I check recursively if parents are BrowserFolders and if yes I store them in my structure.
If folders belong to the top assembly everything is ok.
If folders are nested in other assemblies my algorithm doesn't work.
I've attached an assembly which structure (considering folders) is the image on the right but what I get is the one on the left:
Folder named FolderLev2 is missing.
The iLogic code to reproduce the issue (same behaviour via .net api and Inventor 2017 and 2018):
SyntaxEditor Code Snippet
Class TraverseAssemblyRule
    Const printedTreeFfn As String = "c:\temp\AssemblyTree.txt"
    Private Shared _serializedBrowserFolder As Dictionary(Of String, Object)
    Sub Main()
        Dim oAsmDoc As AssemblyDocument
        oAsmDoc = ThisApplication.ActiveDocument
        _serializedBrowserFolder = New Dictionary(Of String, Object)
        Using sw As IO.StreamWriter = IO.File.CreateText(printedTreeFfn)
            sw.WriteLine(oAsmDoc.DisplayName )
        End Using
        TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
    End Sub
    Sub PrintFolder(browserNode As BrowserNode, ByRef level As Integer)
        Dim browserFolder As BrowserFolder = TryCast(browserNode.NativeObject, BrowserFolder)
        If browserFolder Is Nothing Then
            Return
        End If
        If Not _serializedBrowserFolder.ContainsKey(browserNode.FullPath) Then
            PrintFolder(browserFolder.Parent, level)
            _serializedBrowserFolder.Add(browserNode.FullPath, Nothing)
            Using sw As IO.StreamWriter = IO.File.AppendText(printedTreeFfn)
                sw.WriteLine(Space(level*2) + browserFolder.Name)
            End Using
        End If
        level = level + 1
    End Sub
    Sub PrintOccContaingFolders(occ As ComponentOccurrence, ByRef level As Integer)
        Dim occNode As BrowserNode = ThisDoc.Document.BrowserPanes.Item("AmBrowserArrangement").GetBrowserNodeFromObject(occ)
        If occNode Is Nothing Then
            Return
        End If
        Dim parentNode As BrowserNode = occNode.Parent
        If parentNode Is Nothing Then
            Return
        End If
        PrintFolder(parentNode, level)
        Return
    End Sub
    Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, level As Integer)
        Dim oOcc As ComponentOccurrence
        For Each oOcc In Occurrences
            Dim startingLevel As Integer = level
            PrintOccContaingFolders(oOcc, level)
                sw.WriteLine(Space(level*2) + oOcc.Name )
            End Using
            If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
                TraverseAssembly(oOcc.SubOccurrences, level + 1)
            End If
            level = startingLevel
        Next
    End Sub
End Class
To get the proper structure I should work directly on the ModelBrowserPane (or adopt a mixed solution) because the BrowserNodes property (that returns a collection of the top level BrowserNode objects contained under this node) works.
Here the iLogic code to print the ModelBrowserPane tree as in the image on the right:
Class TraverseBrowserPaneRule
    Const printedTreeFfn As String = "c:\temp\modelBrowser.txt"
    Sub Main()
        Dim modelBrowserPane As BrowserPane = ThisApplication.ActiveEditDocument.BrowserPanes.Item("AmBrowserArrangement")
        Dim topNode As BrowserNode = modelBrowserPane.TopNode
            sw.WriteLine(ThisApplication.ActiveEditDocument.DisplayName )
        End Using
        PrintModelNodeNameRec(topNode, 0)
    End Sub
    Sub PrintModelNodeNameRec(browserNode As BrowserNode, level As Integer)
        Dim name As String
        If browserNode.NativeObject IsNot Nothing AndAlso browserNode.NativeObject.Type <> ObjectTypeEnum.kBrowserFolderObject  _
        AndAlso browserNode.NativeObject.Type <> ObjectTypeEnum.kComponentOccurrenceObject _
        AndAlso browserNode.NativeObject.Type <> ObjectTypeEnum.kComponentOccurrenceProxyObject _
        AndAlso browserNode.NativeObject.Type <> ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
            Return
        End If
        Try
            name = browserNode.NativeObject.Name
        Catch ex As Exception
            'name = browserNode.FullPath
        End Try
        If Not String.IsNullOrEmpty(name) Then
                sw.WriteLine(Space(level*2) + name)
            End Using
        End If
        For Each node As BrowserNode In browserNode.BrowserNodes
            PrintModelNodeNameRec(node, level + 1)
        Next
        Return
    End Sub
End Class
YuhanZhang
This seems an Inventor API bug, I logged this, thanks for reporting it.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
CattabianiI
Thank you @YuhanZhang,
is there an internal issue ID to understand when it is addressed?
YuhanZhang
Please provide 10691 to query its status.
Rocky Zhang
Inventor API PD
