I found a post in Mod the Machine about importing data exchange models into inventor using VBA.
original post: https://modthemachine.typepad.com/my_weblog/2022/04/import-data-exchange-model.html
Sub ImportDataExchangeComponentSample() Dim oDoc As AssemblyDocument Set oDoc = ThisApplication.ActiveDocument Dim sFdx As String sFdx = "https://developer.api.autodesk.com/exchange/v1/exchanges" Dim sUrn As String sUrn = "urn:adsk.wipprod:dm.lineage:**********************" Dim sUrl As String sUrl = sFdx + "?filters=attribute.exchangeFileUrn==" + sUrn Dim oDEDef As ImportedDataExchangeComponentDefinition Set oDEDef = oDoc.ComponentDefinition.ImportedComponents.CreateDataExchangeDefinition(sUrl) Dim oDEComp As ImportedDataExchangeComponent Set oDEComp = oDoc.ComponentDefinition.ImportedComponents.Add(oDEDef) End Sub
I tried it with a few data exchange models that I have on the Autodesk construction cloud and I don't get a model in inventor.
Has any of you tried it?
Funny enough when running the code in the blog post using the urn of an old Data Exchange file I had, I did get the same result: nothing got imported and also got an *.htm file showing an error:
Maybe I don't have access to that exchange file anymore or something went wrong with it - I don't even know where to look for it.
Then I used the urn of another Data Exchange file in ACC, and with that the import worked fine:
Please make sure that you are indeed using the urn of a Data Exchange file, not the original file it was created for, and also open it in ACC to see that it's working fine.
The problem at my end was that we still use Revit 2022 and Data exchange models can be created from Revit 2023+. Also, I skipped the most important step of actually creating a data exchange model in the ACC.
Initially, I thought that every model in the ACC is readily available to grab with that code and imported into Inventor.
Anyway, when I tested with an actual data exchange model and the code works fine.
