The problem at my end was that we still use Revit 2022 and Data exchange models can be created from Revit 2023+. Also, I skipped the most important step of actually creating a data exchange model in the ACC.
Initially, I thought that every model in the ACC is readily available to grab with that code and imported into Inventor.
Anyway, when I tested with an actual data exchange model and the code works fine.
