Announcements
Bolted Connection , Table ... how do I control that I can see in the table ?
Darkforce_the_ilogic_guy
this is the talbe when both inside diameter is 17
and this is if I change one of the to 17,1
so I know now it is possible to get more information , but I can´t seens to control with my knowledge as I want I. I would like to make it possible more information like the material ... so I can see if one of them is steel and the other is brass , but so far I can´t
anyone know how this work ? so I can control what informaion that is show in bolt connection table ?
bradeneuropeArthur
From what I know is that this is not possible in bolted connections.
What I understood is that only original Inventor CC parts are complete usable.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
I can use my own custom family, and I have the option to change a bit what is shown. but haven't 100% figured out how to control it.. what I've found is that it has nothing to do with whether the property is a key property or not .. and the value is not displayed if there are no different values .. somthing must control it
