How can i convert this iLogic code to VBA? i want to change .idw files Creation Date NOW with VBA code.
File-iproperties-creation date- NOW
Could you please help me? or which VBA code should i use?
oTime = Now.ToShortDateString
iProperties.Value("Project", "Creation Date") = oTime
iLogicVb.UpdateWhenDone = True
End Sub
Public Sub main() 'Dim oTime As String 'oTime = Now ' ''oTime. Dim LValue As String LValue = Format(Now, "dd/MMM/yy") MsgBox LValue MsgBox ThisDocument.PropertySets.Item(3).Item("Creation Time").Value ThisDocument.PropertySets.Item(3).Item("Creation Time").Value = LValue End Sub
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Don't understand your last message!
Arthur Knoors
